Lutos
2 years agoTuning in
WIFI Problems
I’m experiencing an issue with my WiFi connection. My Ethernet connection works perfectly, but I can’t seem to get my WiFi to work, it's not showing on the list. I'm using hub 3 m500.
| Acquired Downstream Channel (Hz) | 331000000 | Locked |
| Ranged Upstream Channel (Hz) | 49600000 | Locked |
| Provisioning State | Online |
| 1 | 331000000 | 5.5 | 38 | 256 qam | 25 |
| 2 | 139000000 | 7.3 | 38 | 256 qam | 1 |
| 3 | 147000000 | 6.5 | 37 | 256 qam | 2 |
| 4 | 155000000 | 5.9 | 38 | 256 qam | 3 |
| 5 | 163000000 | 6 | 37 | 256 qam | 4 |
| 6 | 171000000 | 5.8 | 37 | 256 qam | 5 |
| 7 | 179000000 | 5.9 | 37 | 256 qam | 6 |
| 8 | 187000000 | 5.8 | 37 | 256 qam | 7 |
| 9 | 195000000 | 5.8 | 38 | 256 qam | 8 |
| 10 | 203000000 | 5.8 | 38 | 256 qam | 9 |
| 11 | 211000000 | 5.5 | 37 | 256 qam | 10 |
| 12 | 219000000 | 5.5 | 38 | 256 qam | 11 |
| 13 | 227000000 | 5.4 | 37 | 256 qam | 12 |
| 14 | 235000000 | 5.3 | 37 | 256 qam | 13 |
| 15 | 243000000 | 5 | 38 | 256 qam | 14 |
| 16 | 251000000 | 5 | 38 | 256 qam | 15 |
| 17 | 259000000 | 5.1 | 38 | 256 qam | 16 |
| 18 | 339000000 | 6 | 38 | 256 qam | 26 |
| 19 | 347000000 | 6 | 38 | 256 qam | 27 |
| 20 | 355000000 | 6 | 38 | 256 qam | 28 |
| 21 | 363000000 | 5.6 | 38 | 256 qam | 29 |
| 22 | 371000000 | 5.5 | 38 | 256 qam | 30 |
| 23 | 379000000 | 5.5 | 38 | 256 qam | 31 |
| 24 | 387000000 | 5.9 | 38 | 256 qam | 32 |
| 1 | Locked | 38.6 | 300 | 56 |
| 2 | Locked | 38.6 | 204 | 0 |
| 3 | Locked | 37.6 | 238 | 0 |
| 4 | Locked | 38.6 | 228 | 13 |
| 5 | Locked | 37.6 | 172 | 25 |
| 6 | Locked | 37.6 | 229 | 13 |
| 7 | Locked | 37.6 | 213 | 0 |
| 8 | Locked | 37.6 | 197 | 0 |
| 9 | Locked | 38.6 | 222 | 0 |
| 10 | Locked | 38.6 | 230 | 0 |
| 11 | Locked | 37.6 | 290 | 0 |
| 12 | Locked | 38.6 | 251 | 0 |
| 13 | Locked | 37.6 | 275 | 11 |
| 14 | Locked | 37.3 | 278 | 0 |
| 15 | Locked | 38.6 | 324 | 0 |
| 16 | Locked | 38.6 | 260 | 0 |
| 17 | Locked | 38.6 | 300 | 0 |
| 18 | Locked | 38.6 | 416 | 47 |
| 19 | Locked | 38.6 | 399 | 2 |
| 20 | Locked | 38.6 | 471 | 12 |
| 21 | Locked | 38.9 | 391 | 0 |
| 22 | Locked | 38.6 | 402 | 13 |
| 23 | Locked | 38.9 | 364 | 14 |
| 24 | Locked | 38.6 | 352 | 32 |
| 1 | 49600000 | 40 | 5120 | 64 qam | 1 |
| 2 | 36600000 | 39.8 | 5120 | 64 qam | 3 |
| 3 | 23600000 | 38.8 | 5120 | 64 qam | 5 |
| 4 | 43100054 | 39.8 | 5120 | 64 qam | 2 |
| 5 | 30100000 | 39.3 | 5120 | 64 qam | 4 |
| 1 | ATDMA | 0 | 0 | 2 | 0 |
| 2 | ATDMA | 0 | 0 | 0 | 0 |
| 3 | ATDMA | 0 | 0 | 0 | 0 |
| 4 | ATDMA | 0 | 0 | 0 | 0 |
| 5 | ATDMA | 0 | 0 | 1 | 0 |
General Configuration
| Network access | Allowed |
| Maximum Number of CPEs | 1 |
| Baseline Privacy | Enabled |
| DOCSIS Mode | Docsis30 |
| Config file | cmreg-vmdg505-bbt053-b.cm |
| SFID | 4844 |
| Max Traffic Rate | 575000085 |
| Max Traffic Burst | 42600 |
| Min Traffic Rate | 0 |
Primary Upstream Service Flow
| SFID | 4843 |
| Max Traffic Rate | 55000085 |
| Max Concatenated Burst | 42600 |
| Scheduling Type | BestEffort |
Check the Wireless Signal page of the Hub 3 this is at :
Hub 3 menu : Advanced settings >> Wireless >> Wireless signal
For comparison below are our settings and these are working
