Lutos's avatar
Lutos
5 months ago
WIFI Problems
I’m experiencing an issue with my WiFi connection. My Ethernet connection works perfectly, but I can’t seem to get my WiFi to work, it's not showing on the list. I'm using hub 3 m500. Cable Modem ...
    5 months ago
    Check the Wireless Signal page of the Hub 3 this is at :
    Hub 3 menu :  Advanced settings >> Wireless >> Wireless signal
    For comparison below are our settings and these are working
