mikez's avatar
mikez
WiFi problems no internet
I have a superhub 5 and recently it has started behaving very weirdly for about the last week !
The wired ethernet ports always work ok and although the Wifi appears to be up it does not allow any internet traffic.
Strangely I can still ping the router 192.168.0.1 but the router web page itself refuses any connection !
I can talk to everything on my local network 192.68.0.1-192.168.0.255  but can't ping anything on the internet e.g. 8.8.8.8 ,  it doesn't matter which device I use, laptop, phone etc
I've run the status checker and it reports no problems
Rebooting the router sorts it out for a while then it happens again, I tried unplugging it too
Has anyone got any ideas ?
thanks
Mike
  • Hi mikez
    Welcome back to our community forums and sorry to hear you have been having issues with your WiFi connecting both in router and modem mode. We can understand the frustration caused and we want to do our best to help. We are happy to run some tests with you to look into the core issue. For this reason, we have sent a private message. Please keep an eye out for an envelope at the top right corner of your Forum page. Let me know if you have any issues locating this.
  • unisoft's avatar
    unisoft
    Super solver
    Reset hub completely using the PIN hole. Hold the switch inside the pinhole in for around 60 seconds and then release. The hub will reboot itself so do NOT power off, leave it to initialise fully until white (router mode) or green light (modem mode) reappears.
    I'm assuming you haven't changed any IP settings to static addresses on clients and that you've used a clean device that hasn't got affected by malware blah blah blah.....
    • mikez's avatar
      mikez
      Hi,  I've got loads of reserved mac addresses to static IPs and split the 5GHz and 2.4GHz.
      I'm starting to think it may be unstable because I have too many Wifi devices, is there a maximum number the superhub 5 can support ?
      I've just moved all the 2.4GHz to an old router and switched off 2.4GHz on the superhub and now it seems more stable
      Also I've just bought a new router which can support 150 simultaneous devices using MU-MIMO technology,  and may try the superhub in modem mode when the new router arrives.
      I guess even in modem mode the superhub will still do it's occasional reboot around 00:00 to 01:00
        If you have a new Router, I would suggest you use modem mode. You should hopefully find it better.  I've always used any Hub's I've had in modem mode.
  • mikez's avatar
    mikez
    I'm afraid it still isn't working properly, in modem mode I get exactly the same problem and the only thing that solves it is rebooting the superhub.
    Previously it had been working well for a very long time so possibly the number of devices is a bit of a red herring
    I’ve included the status info in case it means something to someone!
    Item Status TypeChannel Overview Downstream Upstream
    Cable Modem StatusOnlineDOCSIS 3.0
    Primary downstream channelLockedSC-QAM
    DOCSIS 3.0 channels315
    DOCSIS 3.1 channels11
    3.0 Downstream channels
    13060000004.943QAM 25622
    21460000003.442QAM 2562
    31540000003.442QAM 2563
    41620000003.842QAM 2564
    51700000003.742QAM 2565
    61780000003.642QAM 2566
    71860000003.942QAM 2567
    81940000004.442QAM 2568
    92020000004.343QAM 2569
    102100000004.843QAM 25610
    112180000004.943QAM 25611
    122260000004.643QAM 25612
    132340000004.343QAM 25613
    142420000004.343QAM 25614
    152500000004.243QAM 25615
    162580000004.143QAM 25616
    172660000004.243QAM 25617
    182740000004.643QAM 25618
    192820000004.643QAM 25619
    202900000004.543QAM 25620
    21298000000543QAM 25621
    223140000004.743QAM 25623
    233220000004.643QAM 25624
    243300000004.843QAM 25625
    253380000004.743QAM 25626
    263460000004.643QAM 25627
    273540000005.143QAM 25628
    283620000005.243QAM 25629
    293700000004.743QAM 25630
    303780000004.843QAM 25631
    313860000005.143QAM 25632
    1Locked4300
    2Locked4200
    3Locked4200
    4Locked4200
    5Locked4200
    6Locked4200
    7Locked4200
    8Locked4210
    9Locked4300
    10Locked4310
    11Locked4310
    12Locked4310
    13Locked4310
    14Locked4300
    15Locked4310
    16Locked4310
    17Locked4320
    18Locked4320
    19Locked4340
    20Locked4310
    21Locked4310
    22Locked4320
    23Locked4320
    24Locked4320
    25Locked4320
    26Locked4320
    27Locked4350
    28Locked4330
    29Locked4330
    30Locked4340
    31Locked4320
    3.1 Downstream channels
    33924K1800QAM 40961128
    33Locked444.0189920410
    3.0 Upstream channels
    04960000044.85120QAM 645
    143100000455120QAM 646
    23660000044.85120QAM 647
    33010000044.55120QAM 648
    42360000044.35120QAM 6411
    0ATDMA0000
    3ATDMA0000
    4ATDMA0010
    3.1 Upstream channels
    1210.440.22KQAM 256
    12OFDMA2087400000000
    General Configuration
    Network accessMaximum Number of CPEsBaseline PrivacyDOCSIS ModeConfig file
    Allowed
    1
    Enabled
    3.1
    cmreg-vmdg660-bbt062-b.cm
    SFIDMax Traffic RateMax Traffic BurstMin Traffic Rate
    127432
    402500089 bps
    42600bytes
    0 bps
    Primary Upstream Service Flow
    SFIDMax Traffic RateMax Traffic BurstMin Traffic RateMax Concatenated BurstScheduling Type
    127431
    38500089 bps
    42600bytes
    0 bps
    42600bytes
    Best Effort
    I can see some errors in the logs but I’m not sure if they only happen immediately after rebooting?
    13-01-2025 22:14:46noticeREGISTRATION COMPLETE - Waiting for Operational status
    13-01-2025 22:14:41warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-01-2025 22:14:33noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-01-2025 22:14:30noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-01-2025 22:14:27warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-01-2025 22:14:25noticeHonoring MDD; IP provisioning mode = IPv4
    13-01-2025 22:14:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-01-2025 22:14:16criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-01-2025 22:14:15criticalCable Modem Reboot because of - HW or Power-On Reset
    thank you for any help !
    Mike
    • Akua_A's avatar
      Akua_A
      No problem at all. Glad to have been able to look into this for you. Please do not hesitate to contact us if you need any further help.
    Stats are fine and I can't see any power level issues etc.   However you mentioned modem mode?  In modem mode there is no Wifi or anything else from the Hub, it's just a "bridge" to the VM network, and needs your own Router to work.  Have you tried another Wifi extender to get your IoT device working?
    • mikez's avatar
      mikez
      Hi, it was all working perfectly for a very long time. Please read my earlier posts.  In attempt to fix/diagnose the problem I have bought another router and am using the superhub in modem mode.    It still works but frequently drops out from the internet, the same as before when not in modem mode.  This applies to ethernet connections as well as Wifi,  something is going wrong in the superhub so that I can't connect to it (using the correct ip address for router and modem modes) or the internet but the local network remains up whether in router or modem mode
      All local wifi connections are working perfectly, when it fails there is no internet connection or ability to connect to the superhub webpage whether in modem or router mode, local connections remain up
      • Akua_A's avatar
        Akua_A
        Hi mikez
    • Steven_L's avatar
      Steven_L
      Hello EmriChollz,
      Welcome back to the Community, and thanks for taking the time to post here on the forums.
      How can we help you today?
      Kind Regards,
      Steven_L
