DCH19501's avatar
DCH19501
WIFI POD problem Model PP01-VM
Had a pod for the last 15 months & it seemed to be working. Recently I have noticed the pod light was flashing & on checking further it is flashing constantly. The WIFI in the house works fine so it would appear the pod is not connecting to the Hub3. Saw a suggestion of connecting it via an ethernet cable (direct into the hub?) & the light stopped flashing. Also a suggestion of a factory pinhole reset but I cannot see such a hole.
Any suggestions of how to get it working again?
Dave
  • Daniel_Et's avatar
    Daniel_Et
    Hi DCH19501 👋 Thank you for your post and welcome to the Virgin Media Community 😀
    We're sorry to hear about the problem you're having 😔
    I can see you've spoken to the team since you posted. Has this issue now been resolved?
    Regards,
    Daniel
    • DCH19501's avatar
      DCH19501
      Hi Daniel,
      Yes, all sorted now & working, thanks.
      Regards,
      Dave
