on 24-05-2024 16:01
Hello,
Recently upgraded my hub (Hub 5) and Wifi package to 1GB (previously 500mb) and have been running my previous set up on Deco M4. I have the Virgin router on modem mode and have 3 Deco's around the house, 1 unit is wired via ethernet next to the hub and the others 2 is on wifi. On my previous package I would get arounds 300-350 speeds (on 500mb package) which was fine, but since i have upgraded to 1GB i have seen no improvement on my speeds apart from upload speeds (80-90).
Before putting the Virgin Hub5 on modem mode I tested the speed (on wifi) and got 750-800mb speeds which is fine as its not wired in via ethernet. But since putting it on modem mode, and using the Deco M4's (like i used to) i am seeing around 50% drop off speeds.
Does anyone know if its achievable to get around 700-800+ on Deco M4s? or is it simply that i need to upgrade them to more powerful units. if anyone is getting close to 1gb via a mesh system, could you let me know what model / set up you have please?
thank you
on 24-05-2024 16:29
The Deco M4 are Wifi 5 ac protocol. The Hub 5 is Wifi 6 ax protocol. Time for an upgrade if it's Wifi speed you are after.
