chris3000's avatar
chris3000
Hub 5 router mode and Deco X50-POE
Hi. I have had a hub 5 installed and it works fine on its own providing wifi and a signal to my TV and alarm system by ethernet cat 6. However my network of two Deco X50-POEs don't receive any internet signal except for a moment when the main deco receives it during setting up then seconds later loses it. When I reset the hub or restart the decos the main deco shows a green light but as soon as i connect to its network the light goes red.
After seeking advice from TPIink I have wired my main deco by ethernet cat 6 cable to the hub 5 via a POE injector and then daisy chained the other deco to the main deco via a second POE injector also by cat 6. This according to TPlink is router mode and enables ethernet backhaul. I have tried this set up with the hub 5 in both router and modem modes and nothing works. My preference would be to keep the hub 5 in router mode so I can still connect my TV and alarm from its LAN sockets and avoid rewiring with a switch. I understand that this is not possible with the hub 5 in modem mode as only one LAN socket works.
I would like to ask the community if there is any advice or opinion you would be willing to share. Thanks in advance for your assistance.
  • Have you tried via the included power adapter instead of POE?
    Yes, you should be able to piggy back between the Decos over ethernet, even when in access point mode.
    • chris3000's avatar
      chris3000
      Thanks for the response. Yes have done that too with no luck. Does the backhaul through the ethernet cable work in that mode too?
      • carl_pearce's avatar
        carl_pearce
        Superstar
    If the Deco are connected via the Hub 5's troubled 2.5Gb/s port try using a 1Gb/s port of the Hub 5
