on 19-01-2024 22:33
So, been on chat with an agent now for an hour, and he is Refusing to send out the Hub 5 point blank.
I have had 1GB since it was available in my area, I am also Loooong out of contract.
There Are other GB providers in my area soon, and as soon as they are, I am gone Unless they provide the Hub 5.
They said they would send an engineer but if there was no fault I'd be charged £25 !!!
II have been with VM for 2 decades now, in one name or another, Not for very much longer if they continue with this level of customer 'service' !!!
on 19-01-2024 22:59
Adding insult to 'injury', their customer 'support agent' just left without a word.
Really makes you feel wanted? Not.
on 19-01-2024 23:01
VM equipment is rented, you cannot demand what you want. You are supplied with equipment adequate for you speed tier, that could be a hub4 or a hub5. Unless you are running your own router that accepts a 2.5G signal as input there is not much to be gained by having a hub5.
on 19-01-2024 23:15
Good customer service is not rented, but the opinion of the company continues to go down
on 20-01-2024 00:02
And I noticed that you totally ignored the fact that the agent just left, with no word as to what was happening.
on 20-01-2024 00:19
What is wrong with your circuit that you need an engineer?
Also if you are out of contract and there are other ISP’s that’s great
on 20-01-2024 06:18
You tell me. That is whar rge agent said
20-01-2024 11:12 - edited 20-01-2024 11:12
It's not "my agent", I don't work for VM. This is a Community Forum and a lot of the replies are just other VM users trying to help each other.
If you wait a few days a VM member of staff will reply to you directly.
20-01-2024 11:47 - edited 20-01-2024 11:47
If you don't like the service, and you have alternatives, just go.
20-01-2024 17:46 - edited 20-01-2024 17:48
VM will likely be forced to give out hub 5 when speed goes past 1Gb even if 1Gb now goes past 1Gb its still 1Gb ports to 1Gb speed.
