Unstable Connection
Neilk84
Hi All
Ive just had broadband installed 1 gig with hub 5. Getting great speeds, but everytime i run a speed test on the Ookla speedtest app. Before i start it. The circle shows in yellow and says my internet connection may be unstable. Ive never experienced this before, as it is usually green and good to go. Ive tried power cycling everything, and even factory resetting hub, this hasnt changed anything. Ive tried this on other providers and even family memebers virgin broandband, no of them show this warning. Just my connection. I have FTTP.
Also i am waiting on my first wifi pod that has never arrived after over a week of waiting, after being told it would be with me in 72 hours.
All help appreciated
7 REPLIES 7
Which Hub do you have exactly? The Hub 5 or Hub 5X ?  For XGS-PON fibre it will be the 5X
Its the 5. Fibre comes into my house to a small white box, then coaxout from that to the hub 5
Cardiffman282
Trouble shooter
Check for local faults on 0800 561 0061
Cancel VM here
Complain to VM
here
Demand compensation from VM here
Demand your call recordings here
Monitor the state of your VM connection here
Hey Neilk84, thank you for reaching out and I am so sorry to hear this.
I can see you are currently in a DM with my colleague, please do reach out if you need some assistance still.
Matt - Forum Team
New around here?
Anonymous
Not applicable
Did you ever get to the bottom of this?
it sorted itself out not long after i posted this. im guessing someone looked into it.
Anonymous
Not applicable
Weird. Mine does it some days, not others. Thanks for getting back to me.
