on 24-06-2024 22:00
Hi there.
I have a super hub 3, wired it’s fine but wireless it drops sometimes in the day and the hubs WiFi top light flashes green uncontrollably for about 2 minutes then goes back to normal, the hub does not restart or anything and it’s super weird, makes me think it’s the hub as the wired connection works fine.
any ideas?
on 25-06-2024 15:47
Well if ethernet connections are all good then either there is a problem in the Hub's wifi "circuitry" - or you have some wifi inerference. Do wifi connections drop on all of your devices at the same times?
Is there anything unusual showing in the Hub's network logs?
on 27-06-2024 16:46
Hi Jackwelch86,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issues you've had with your Wireless connection.
Can you confirm if you are still having this issue?
^Martin
27-06-2024 17:32 - edited 27-06-2024 17:36
That description fits with WPS pairing activity (taken from)
https://www.virginmedia.com/help/how-to/broadband/hub-lights
Perhaps a hub fault? Try turning off WPS on the hub from the hub interface if it is on (many would choose to have it disabled anyway)
