Matrpanir's avatar
Matrpanir
Super hub 2, no ethernet and wifi flaky
Internet has been slow for a couple of days,  particularly adely before connecting to a site but now the ethernet has stopped completely. I use a desktop for work so this is a real problem! I'm trying to work on a tablet but it's not great.
The wifi more or less OK most of the time but just seems to stop periodically and only  the 5 Ghz band works which is annoying as I have a very old wifi dongle but only 2.4Ghz.
I went through the VM help pages and have reset the hub several times, turned it off and on and checked all the connections.
Help!
Matt
  • Forgot to mention that in VM online help tested the hub and said to reset,  but that didn't work .
    Matt
  • legacy1's avatar
    You need a new hub unless their is a problem in your area
    • Matrpanir's avatar
      Matrpanir
      Thanks for replying, there's not a problem in the area,  so I guess I need a  new  hub.
      Is there a straightforward way to request one?
      • Beth_G's avatar
        Beth_G
        Hi Matt
        Thanks for your post - sorry to hear that you've been having issues with your broadband connection.
        I've had a look from this side and can see there's a few issues with your signals which will need ironing out through an engineer visit. So it looks like the Hub may not be the issue, however I will ask if the engineer can swap out your Hub too to a more modern model.
        I've dropped you a PM so I can take your account details and book in a visit for you.
