amadi8
1 year agoTuning in
Speed is capped on ethernet cable at 100mbit
Hi, I have a similar problem as previously reported, with the Ethernet cable being capped at 100 Mbps. I have already ruled out everything other than the Hub 5, which I have.
- I have a Cat6 Ethernet cable and tested it with a laptop, resulting in the same issue.
- My PC network card is running at a full 1 Gbps speed.
- The port I use on the Hub is 2.5 Gbps.
Please advise why my PC is only receiving 100 Mbps.
What you haven’t done is try another Ethernet cable. 100M usually indicate one of the eight wires in the cable is disconnected or broken.
