on 21-05-2024 11:26
My hub 3 has a solid orange light at the bottom and flashing red telephone light. Virgin diagnostics tell me there's a problem with the hub (!) but they tried to reset it remotely and failed, manual reset via the button failed as did just turning it off and having a cup of tea.
Previous analysis by Virgin said a problem and call an engineer (have you tried). Broadband speed seems there as does the telephone light, so suspect the hub's shot.
Any help or ideas welcome
Answered! Go to Answer
on 21-05-2024 16:53
Apart from an orange light (that's normal!) and flashing telephone light... what actual issues are you experiencing on your connections?
on 21-05-2024 16:53
on 21-05-2024 17:20
Hi John
Actually the broadband speeds are what they should be but what I read is that if the light at the bottom of the hub is orange or red, then there is either a tech problem or the hub is overheating. The red flashing telephone light only started once Virgin said the hub need to be factory reset and they tried it remotely (20 min one) and after 2 mins, said they couldn't do it but to press the reset button for 15 secs min (did 20 secs) and that did nothing.
During the reset, get a few flashing green ones.
When the hub was new, the orange light was white.
I dont pretend to know much about the tech side but this has only been orange for the last 6 weeks
Thanks fr coming back
Bob
on 22-05-2024 15:29
The orange LED on a Hub3 is a common "feature" of all ageing units. Probably due to fading/failing in the 1p LED just ignore it. My daughter just joined VM last week and she was issued with a refurbished Hub3 (there havent been any new ones for years) and yes - you guessed it - the light was already orange - here is the pic she sent me to ask the same question...
If it goes bright red then it does need attention. Its either an overheating hub - or one where that detection system is now compromised.
on 22-05-2024 15:41
Thank you for that John, most helpful to us "non techies". I shall just ignore it until it goes red;
Bob
on 23-05-2024 08:04
Like all the other posters above, I have now a solid red light on my hub 3 and its quite hot to the touch. I have had a solid orange light but its now definitely solid RED.
I have tried the pinhole reset and the turning it on and off reset, all to no avail. Virgin tried to reset it remotely, this also failed after 2 minutes.
Need some help and quickly from Virgin guys here please, none of us can live without our internet.
bw2020
02-06-2024 15:37 - edited 02-06-2024 15:43
@abroves wrote:Why is there an orange light on my Virgin Media Hub3?
It was white when new - but because yours is now a 5-10 year old gizmo which was originally built using a 1p LED it is now losing its will to shine,,, All LED's fade over time - its a well documented phenomenon
on 02-06-2024 19:52
Hello All
Thanks for your interest.
This got picked up by the Virgin Moderators when orange turned more red. In short, they got an engineer here within a couple of day and on time, who looked at it and pronounced it faulty and changed it for a hub 5. He set it up and we checked the coverage which was better.
Smiles all round
Bob
on 02-06-2024 19:54
The mans right, clapped out LED but with mine the hub worked well. Orange turned to red, Virgin got involved through this forum, engineer came and changed hub.
Bob
02-06-2024 23:08 - edited 02-06-2024 23:10
Yes... if it fails to red it has to be changed as the system for detecting overheating is compromised - so has to be rectified for "safety" reasons.
Chances are though is that they will simply send out a refurbished Hub3 - but on the other hand - when you get a Tech visit, they are more likely to just swap it out for a Hub4 or 5 as that's probably what their van is stocked with 😎
