Slow ethernet speed
Aaronwolfy
Got the gig 1 package with the virgin hub 5, get around 800 mbps over wifi so all is well there but on my desktop I can manage at best 330mbps, I've went through guides everywhere, putting on latest drivers, putting on basic drivers, changing mtu sizes and settings for 1gb duplex etc, my desktop is on a 1300mps powerline adapter from tp link, I've tried the desktop plugged straight in to the router too to rule out the powerline adapter being at fault despite the poweline adapter telling me it's got a connection of over 900mps between, tried my laptop and on the WiFi that can hit around 700 but on ethernet it can also only reach 320 mbps, I've tried every port on the hub 5, I have installed windows 11 and I am still not getting any better than 320mbps, so unless every ethernet port on the hub 5 is faulty I am at a loss as what to do
17 REPLIES 17
You have said though that you only get the 300-ish Mbps when you are connected direct to the hub so the powerline speed is a bit irrelevant at this point if the speed connected direct to the hub is only 320 Mbps via ethernet.
carl_pearce
Community elder
Try wired directly to the HUB, not with the powerline adapter, and in safe mode with networking:
https://www.bleepingcomputer.com/tutorials/how-to-start-windows-10-in-safe-mode-with-networking/
Aaronwolfy
I have taken the pc directly to the hub and tried the cables I have on hand, a cat5e, cat6 and a new cat 8 and the results are the same, my laptop which does have gigabit also pulls the same speed on ethernet but is able to get 913mbps on the wifi, it's like all the ethernet ports on the hub 5 are locked down too 320mbps
Hi there @Aaronwolfy
Thank you so much for your post and welcome to the community forums, it's great to have you.
I am so sorry that you have faced an issue with your connection and a big thank you to our community for their help so far.
I have checked this on our side and I cannot see any issues that may be causing this.
Can you post your Hub status and logs? How to do this;
• Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. Please do not include your MAC address.
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum
Cable Modem Status
Item Status Type
Cable Modem Status Online DOCSIS 3.0
Primary downstream channel Locked SC-QAM
Channel Overview Downstream Upstream
DOCSIS 3.0 channels 32 5
DOCSIS 3.1 channels 1 1
3.0 Downstream channels
1 331000000 6.7 39 QAM 256 25
2 139000000 7.9 39 QAM 256 1
3 147000000 7.6 39 QAM 256 2
4 155000000 7.5 39 QAM 256 3
5 163000000 7.5 39 QAM 256 4
6 171000000 7.4 39 QAM 256 5
7 179000000 7.3 39 QAM 256 6
8 187000000 7.1 39 QAM 256 7
9 195000000 7.3 39 QAM 256 8
10 203000000 7.1 39 QAM 256 9
11 211000000 7.2 39 QAM 256 10
12 219000000 7.2 39 QAM 256 11
13 227000000 7 39 QAM 256 12
14 235000000 6.9 39 QAM 256 13
15 243000000 6.8 39 QAM 256 14
16 251000000 6.3 39 QAM 256 15
17 259000000 5.8 39 QAM 256 16
18 267000000 5.8 39 QAM 256 17
19 291000000 6.4 39 QAM 256 20
20 299000000 6.5 39 QAM 256 21
21 323000000 6.8 39 QAM 256 24
22 355000000 7.8 40 QAM 256 28
23 363000000 8.2 40 QAM 256 29
24 387000000 8.6 40 QAM 256 32
25 395000000 8.4 40 QAM 256 33
26 403000000 8.1 40 QAM 256 34
27 411000000 7.7 40 QAM 256 35
28 419000000 7.4 40 QAM 256 36
29 427000000 7.2 40 QAM 256 37
30 435000000 6.6 39 QAM 256 38
31 443000000 6 39 QAM 256 39
32 451000000 6.1 39 QAM 256 40
1 Locked 39 4 0
2 Locked 39 8 0
3 Locked 39 5 0
4 Locked 39 5 0
5 Locked 39 5 0
6 Locked 39 3 0
7 Locked 39 3 0
8 Locked 39 4 0
9 Locked 39 4 0
10 Locked 39 11 0
11 Locked 39 5 0
12 Locked 39 20 0
13 Locked 39 24 0
14 Locked 39 8 0
15 Locked 39 5 0
16 Locked 39 8 0
17 Locked 39 5 0
18 Locked 39 10 0
19 Locked 39 7 0
20 Locked 39 4 0
21 Locked 39 3 0
22 Locked 40 8 0
23 Locked 40 6 0
24 Locked 40 9 0
25 Locked 40 6 0
26 Locked 40 6 0
27 Locked 40 5 0
28 Locked 40 6 0
29 Locked 40 5 0
30 Locked 39 9 0
31 Locked 39 1 0
32 Locked 39 17 0
3.1 Downstream channels
159 94 4K 1840 QAM 4096 1108
159 Locked 37 4.5 701732893 7
3.0 Upstream channels
0 49600000 43 5120 QAM 64 1
1 43100000 43.3 5120 QAM 64 2
2 36600000 44 5120 QAM 64 3
3 30100000 43.8 5120 QAM 64 4
4 23600000 43.5 5120 QAM 64 5
0 ATDMA 0 0 0 0
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 3 0
4 ATDMA 0 0 0 0
3.1 Upstream channels
6 10 36.2 2K QAM 256
6 OFDMA 200 74000000 0 0
General Configuration
Network access Allowed
Maximum Number of CPEs 1
Baseline Privacy Enabled
DOCSIS Mode 3.1
Config file 4k;fg87dsfd;kfoA,.iyewrkl
SFID 5534
Max Traffic Rate 1200000450 bps
Max Traffic Burst 42600bytes
Min Traffic Rate 0 bps
Primary Upstream Service Flow
SFID 5525
Max Traffic Rate 110000274 bps
Max Concatenated Burst 42600bytes
Scheduling Type Best Effort
Apologies for late reply been stuck with work, I have posted the requested info, from all I can see is that the router and connection are perfectly fine it's just the ethernet ports on the router just aren't putting out any speed above 320mbps
Thanks for coming back to us Aaronwolfy, we may need to arrange an engineer visit to resolve the issues that you're experiencing and most likely to replace your router.
I can arrange the appointment from here but would need to confirm a few details via a private message, that I will drop over in a moment. Please look out for the private message and we can get started.
Kind Regards,
Steven_L
Thats all booked in for you now and if you get the chance after the visit, please let us know how it went.
Kind Regards,
Steven_L
