- legacy1Alessandro Volta
by wireless?
- asus11111Joining in
Yes by wireless,but same speed by cable cat7
- jpeg1Alessandro Volta
The most you will get over ethernet to one device is 940Mbps.
So why is jumping between 550+
Why is not stable like 800-850mbps all the time?
Can some routers replace this hub 5?
Your line is shared others in the area can be downloading causing the average to drop for faster upto speed only when many stop downloading does the average go up for your upto speed to run high
run by wire this and check download latency
Forgetting WiFi which will always be variable,
You can check if there are local issues affecting you, phone 0800 561 0061.
If you want help diagnosing a possible problem, point your browser at the Hub, copy and paste here the upstream, downstream and log data. As text, not screenshots.
- grumpywurzelDialled in
I guess it depends really on if you are connected to the router in wireless or wired and the age/type of device in use..
For example, if I'm virtually sat ontop of the VM box, with a reasonably modern mobile device (Pixel 6 phone for this test) I'll be v lucky to get around 800-900mbps. Move to my office/spare room (with 2 pods to boost signal in the house) and it drops to ~550mbps. Same setup but using wired (direct to router and later to a pod in the office), I get the full 1gig download speed and in the office I'll get ~680 ish.
Slightly older wireless tech, such as my Samsung Tab 7, sees a drop of around 50-100mbps at exactly the same position.
I'm probably wrong but when ISP's advertise the speeds, it's the total combined across all devices and an "up to" value, somewhere in the blurb they will state a guaranteed minimum speed.
To be honest, there's probably nothing you can do to get the full 1 gig on a single device, also factor in times of day as well, as that has a big impact on your download speed.
Related Content
- 2 years ago
- 5 months ago
- 2 years ago
- 2 years ago
- 2 years ago
