Replacement super hub 3 configuring
fedup007
I have just received a replacement Hub 3. I am trying to change  the wifi network name and wifi password on the new hub to those from the old hub by using 192.168.0.1.
All goes well until it gets to 5 GHz WiFi configuration. I can change the SSID but everything below that is greyed out. Is this normal and OK for me to go ahead?
Please do not advise I use the Virgin Connect app I have spent the last hour trying to do that and it will not play ball.
Thanks for any advice that is offered
6 REPLIES 6
The VM Connect app will prevent you from adjusting the Wi-Fi of the Hub.
Go ahead and uninstall the Connect app, being closed is not enough to prevent it tinkering with the Hub settings.
In the Hub 3 menu   Advanced Settings >> Wireless >> Wireless Signal
bottom of the page, Disable the Smart Wi-Fi / Wireless Channel Optimization option,
this will enable settings changes for the 5GHz Wi-Fi.
Thank you but that has made no difference; security  and wifi password still  greyed out
nodrogd
More than likely you will need to factory reset the hub & start again.
VM 350BB 2xV6 & Landline. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Cable customer since 1993
jpeg1
And after the factory reset you will need to turn off the Smart WiFi again.
- jpeg1
My name is NOT Alessandro. That's just a tag Virginmedia sticks on some contributors. Please ignore it.
( 5GHz ) Security and wifi password still greyed out
When I change the SSID of the 5GHz band the Security and Password are re-enabled,
If the 2.4 & 5 GHz bands have the same SSID the Security + Password of the 2.4 GHz Wi-Fi is used for both bands.
fedup007
Thank you all for your comments...after taking the dog for a long walk to calm my frustration I logged into my hub again as per VM help "Changing the WiFi network name or password" Once I reached stage 3  I completely ignored the instructed steps regarding advanced settings,, went to Configure your WiFi network  section and hey presto everything is up and running.
