Wednesday
I've been having issues with my broadband speed for about a week now. I'm on Gig1 full fibe, with a Hub 4 router, and regularly get 950-985 Mbps download and about 100 Mbps upload.
On 5 Sept, I began to notice that webpages were loading incredibly slow, and performed a speed test. The download speed had dropped to 12.88 Mbps, but the upload speed was 104.80 Mbps. I turned the router off, and unplugged it for a few minutes, then plugged it back in. After a while I did another speed test and it was 945.93 and 104.88 Mbps.
I had the same problem yesterday, 10 Sept, with speeds of 0.91 Mbps and 102.43 Mbps. Again, after cycling the router, speeds were 945.98 and 104.89 Mbps.
The same problem then hit today, so bad that I couldn't even get speed test page to load. I tried to access the Internet through the Hub 4 router on both desktop (via Ethernet), and on mobile (via WiFi). Both encountered same issue. I finally got the speed test to work on my mobile, which registered 0.10 Mbps download.
I then tried logging into my account through the My Virgin Media app. When I tried to move on from the email login page I got a "Sorry, something's gone wrong" page, with the error code: FSB50. I was able to login to the router (192.168.0.1) and ran the Network Diagnostic Tool, but all this said was that "Your home network has a few problems", without giving further details.
I've had to access My Virgin Media account through mobile data. I ran through a Service status check and received an error for broadband, with an "Intermittent signal in your area" message.
After repeating the same routine (cycling the router), the problem was fixed - to a point. unfortunately, I'm getting 1/2 my download speed, at 437.49 Mbps, while the upload speed is consistent at 104.84 Mbps.
Is it the signal itself, or the Hub 4 router? I can't be expected to repeatedly cycle the router if this is going to be a regular occurrence.
Answered! Go to Answer
Wednesday - last edited Wednesday
The preferred Power levels for the 3.1 Downstream are -7 to +7 dBmV
Here the figure is -14.6 dBmV, as this is a logarithmic scale, the received signal is a tiny fraction of what is expected,
this is likely the root cause of your variable speed issues.
You can try to request an engineer to be sent to rectify this, but I'd not be surprised if this turns out to be a fault in a street cabinet or even further back in the network that is affecting many customers in your locality.
3.1 Downstream channels
159 | Locked | 29 | -14.6 | 112998535 | 1297 |
Wednesday
Lets see the connection data - see this...
Post up your Hub/network connection details and someone will check to see if there is a problem there. In your browser’s URL type in 192.168.0.1 if in router mode or 192.168.100.1 if in modem mode. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
Wednesday
part 2 of 2
Time | Priority | Description |
Wed Sep | 6 | CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Wed Sep | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Wed Sep | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Wed Sep | 6 | CMSTATUS:US_Diplexer_Mode_Change_Ignore: (TLV-9) , (5-85) ;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Wed Sep | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Wed Sep | 6 | CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep | 6 | CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep | 6 | CMSTATUS:US_Diplexer_Mode_Change_Ignore: (TLV-9) , (5-85) ;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep | 3 | No Ranging Response received - T3 time-out;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep | 6 | CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Mon Sep | 3 | No Ranging Response received - T3 time-out;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Mon Sep | 6 | CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Mon Sep | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Mon Sep | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Mon Sep | 6 | CMSTATUS:US_Diplexer_Mode_Change_Ignore: (TLV-9) , (5-85) ;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Mon Sep | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Sun Sep | 6 | CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Sun Sep | 3 | No Ranging Response received - T3 time-out;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Sun Sep | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Sun Sep | 3 | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Sun Sep | 3 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Sun Sep | 5 | TCS Partial Service;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1; |
Wednesday
25 | 331000000 | 8.000000 | 36.386890 | QAM256 | 25 |
1 | 139000000 | 8.500000 | 31.403784 | QAM256 | 1 |
2 | 147000000 | 8.400002 | 31.688669 | QAM256 | 2 |
3 | 155000000 | 8.400002 | 31.993563 | QAM256 | 3 |
4 | 163000000 | 8.099998 | 32.237156 | QAM256 | 4 |
5 | 171000000 | 7.800003 | 32.237156 | QAM256 | 5 |
6 | 179000000 | 7.699997 | 32.676208 | QAM256 | 6 |
7 | 187000000 | 7.900002 | 32.676208 | QAM256 | 7 |
8 | 195000000 | 7.599998 | 32.676208 | QAM256 | 8 |
9 | 203000000 | 7.300003 | 32.962662 | QAM256 | 9 |
10 | 211000000 | 7.199997 | 33.062504 | QAM256 | 10 |
11 | 219000000 | 7.500000 | 33.376591 | QAM256 | 11 |
12 | 227000000 | 7.400002 | 33.486542 | QAM256 | 12 |
13 | 235000000 | 7.199997 | 33.834164 | QAM256 | 13 |
14 | 243000000 | 7.000000 | 33.834164 | QAM256 | 14 |
15 | 251000000 | 7.500000 | 33.486542 | QAM256 | 15 |
16 | 259000000 | 8.099998 | 34.925610 | QAM256 | 16 |
17 | 267000000 | 8.300003 | 35.595078 | QAM256 | 17 |
18 | 275000000 | 8.699997 | 35.595078 | QAM256 | 18 |
19 | 283000000 | 8.699997 | 35.595078 | QAM256 | 19 |
20 | 291000000 | 8.500000 | 35.595078 | QAM256 | 20 |
21 | 299000000 | 7.699997 | 35.595078 | QAM256 | 21 |
22 | 307000000 | 7.199997 | 35.779911 | QAM256 | 22 |
23 | 315000000 | 7.199997 | 35.779911 | QAM256 | 23 |
24 | 323000000 | 7.500000 | 36.609653 | QAM256 | 24 |
26 | 339000000 | 7.900002 | 36.386890 | QAM256 | 26 |
27 | 347000000 | 7.699997 | 36.386890 | QAM256 | 27 |
28 | 355000000 | 7.500000 | 36.386890 | QAM256 | 28 |
29 | 363000000 | 7.099998 | 35.779911 | QAM256 | 29 |
30 | 371000000 | 6.900002 | 35.595078 | QAM256 | 30 |
31 | 379000000 | 6.900002 | 35.595078 | QAM256 | 31 |
32 | 387000000 | 6.800003 | 36.386890 | QAM256 | 32 |
25 | Locked | 36.386890 | 0 | 0 |
1 | Locked | 31.403784 | 0 | 0 |
2 | Locked | 31.688669 | 0 | 0 |
3 | Locked | 31.993563 | 0 | 0 |
4 | Locked | 32.237156 | 0 | 0 |
5 | Locked | 32.237156 | 0 | 0 |
6 | Locked | 32.676208 | 0 | 0 |
7 | Locked | 32.676208 | 0 | 0 |
8 | Locked | 32.676208 | 0 | 0 |
9 | Locked | 32.962662 | 0 | 0 |
10 | Locked | 33.062504 | 0 | 0 |
11 | Locked | 33.376591 | 0 | 0 |
12 | Locked | 33.486542 | 0 | 0 |
13 | Locked | 33.834164 | 0 | 0 |
14 | Locked | 33.834164 | 0 | 0 |
15 | Locked | 33.486542 | 0 | 0 |
16 | Locked | 34.925610 | 0 | 0 |
17 | Locked | 35.595078 | 0 | 0 |
18 | Locked | 35.595078 | 0 | 0 |
19 | Locked | 35.595078 | 0 | 0 |
20 | Locked | 35.595078 | 0 | 0 |
21 | Locked | 35.595078 | 0 | 0 |
22 | Locked | 35.779911 | 0 | 0 |
23 | Locked | 35.779911 | 0 | 0 |
24 | Locked | 36.609653 | 0 | 0 |
26 | Locked | 36.386890 | 0 | 0 |
27 | Locked | 36.386890 | 0 | 0 |
28 | Locked | 36.386890 | 0 | 0 |
29 | Locked | 35.779911 | 0 | 0 |
30 | Locked | 35.595078 | 0 | 0 |
31 | Locked | 35.595078 | 0 | 0 |
32 | Locked | 36.386890 | 0 | 0 |
159 | 96 | 4K | 1840 | QAM1024 | 759 |
Wednesday
1 | 49600000 | 41.770599 | 5120 KSym/sec | 64QAM | 1 |
2 | 23600000 | 40.270599 | 5120 KSym/sec | 64QAM | 5 |
3 | 30100000 | 41.270599 | 5120 KSym/sec | 64QAM | 4 |
4 | 36600000 | 41.270599 | 5120 KSym/sec | 64QAM | 3 |
5 | 43100000 | 41.270599 | 5120 KSym/sec | 64QAM | 2 |
1 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
5 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
6 | 10.0 | 44.0 | 2K | QAM128 |
6 | OFDMA | 200 | 53.9 | 0 | 0 |
Wednesday
Although the Downstream power levels are strong, the SNR ratio is close to or at the lower limits.
Is there a known service fault in your locality - (do try both) ?
Call 0800 561 0061 – this is an automated number.
https://www.virginmedia.com/help/check/status/identification/identify
Speed test the service to a Router mode Hub(3/4/5) + your device with the link below.
Once the test begins click on: Run full test to include: Latency, Jitter, Packet loss & Upload speed
The speed at the Hub should reflect your subscription
Wednesday
The automated number indicated that there were NO issues in the area. Confusingly, following the VM link, it stated that there was an "Intermittent signal in your area. We’re looking into it. Check back here after 21 hours, and if there’s still an issue we’ll help you book an engineer."
This was the result using the check VM speed test tool.
Latency 16.7 ms
Jitter 0.52 ms
Download 74.0 Mbps
Upload 103 Mbps
Do I wait nearly 24-hours, or book an engineer? This has been ongoing for nearly a week.
Wednesday
Thank you for this.
I think I'll wait until tomorrow. If I'm still having problems then, I'll book an engineer.
Thursday
Lets see the BQM.
