on 06-06-2024 16:51
So my hub 3 that I’ve had since 2019 and now the red light is staying on I’ve called in but was told to wait for 24 hrs as my connection is dropping I go away on holiday soon and need it sorting everything says the rooter is overheating but I need it on for the cctv ect. The room is cool and sits at 17oC with air conditioning rooter makes a horrid grinding noise photo including any advice anyone
on 06-06-2024 17:15
Power it down for five minutes and try again. If still red it's fried and you need a replacement hub via another call to VM on 0345 454 1111 / 150.
on 06-06-2024 18:04
Run the Network diagnostic tool ( from the Hub 3 menu )
Scroll down through the results and find the Temperature entry. Is it normal ?
on 08-06-2024 09:36
Hi jasoneliott1988,
Thank you for your post and welcome to the community.
We're very sorry to hear about the issues with your broadband service.
I have taken a look on our side and I can see you have spoken with the team regarding this.
Do you still require assistance with this?
^Martin
