Nivek85's avatar
Nivek85
10 months ago
Red light always on - V3 Router
Since installation 1yr ago, my Virgin V3 router has displayed a permanent red light. The installer didn't seem bothered by it. Anyway, reading the forum it seems that this indicates overheating. What should  do?
  • Hi Nivek85
    I've moved your post from the tech chatter forum which isn't manned by the forum team, and merged it with your original post.
    Have you responded to the PM that was sent to you on the 4th December by Forum Staff?
    If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox.
    If you are on a mobile/tablet device then click on the little circle icon in the top right  and then select 'Messages'.
  • md009a3226's avatar
    md009a3226
    Seriously?!  Put it somewhere cooler, or with more airflow, and if it is already in a cool place, then ask VM for a new one as it's broken. What temperature is it beside where your modem/router is?
  • Tudor's avatar
    There is definitely a problem with Hub3s and it will probably need replacing. Do a pin-hole reset of the hub and if the red LED persists then the hub will need replacing. A VM staff member should get to your post today or early tomorrow.
  • Hello Nivek85
    We're sorry to hear of the red LED on your Hub 3, we appreciate you raising this with us via the forums and welcome to the community.
    We're eager to get this looked into I will send you a Private Message, please keep an eye out in the top right when signed into the forums for the envelope. This is where you will be able to find my Private Message and be able to respond.
    In the meantime, please ensure the following:
    • Ensure the Hub is upright, in a well-ventilated location and out of direct sunlight, if possible.
  • Can a technician contact me re this, which from other posts appears to be an overheating issue. I've reset the hub, it is out in the open and doesn't feel hot, just warm. The broadband speed is very intermittent as well.
      Hi Nivek85
  • I’ve got this too and live chat no help. Can anyone here help?
    • Robert_P's avatar
      Robert_P
      Hello Jill471
      We're sorry to hear of the red light on your Hub, we appreciate you raising this via the forums and we're happy to help.
      We can see you have spoken to the team and a resolution offered, keep us up to date with this and let us know if you need further assistance.
