Annekaaaa's avatar
Annekaaaa
Re: Red light on hub
Could you inbox me too please, Having same issues tried online chat and tried calling but the call has been dropped several times. done all the switching on /off resetting and still have issues
1 Reply
  • Zach_R's avatar
    Zach_R
    Hi Annekaaaa,
    Thank you for your post and welcome back to our community forums. We're here to help.
    I'm so sorry to hear of the issues you're facing with your Hub. If you haven't done so already then please follow each of the steps listed below.
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
    If you've followed the steps above and the issue remains then please respond to the private message that I'll be sending to you shortly and we can proceed from there.
