- Client62Alessandro Volta
From the Hub 3 admin menu, run Network Diagnostic tool,
check the results to see if Temperature is normal.- malc433900Joining inYour home network has a few problems.
Checking Broadband Service
Checking Telephone Service
Checking Ethernet Connections
Checking WiFi ConnectionsIf you still think something is wrong, please check the following1 Gateway IPv4 address is valid. 2 Your broadband connection is working. 3 Your broadband connection is ready. 4 The temperature of your Hub 3.0 is normal. 5 The status of telephone line 1 is not ready. 6 The status of telephone line 2 is not ready. 7 The device [id] has low signal strength, please move it closer to Hub 3.0. 8 The device [id] has low signal strength, please move it closer to Hub 3.0. 9 The device [id] has low signal strength, please move it closer to Hub 3.0. 10 Please place your WiFi device near the Hub 3.0. - David_Bn
Thanks for coming back to us malc433900.
Do please work with my colleague who has advised of their private message, who will be able to have this resolved for you
David_Bn
- AdduxiVery Insightful Person
If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
- Daniel_EtForum Team (Retired)
Hi malc433900, thank you for your post.
In order to discuss this with you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
Thank you for your support Client62 and Adduxi 👍
Regards,
Daniel
Related Content
- 2 years ago
- 4 years ago
- 2 months ago
