- Daniel_EtForum Team (Retired)
Hi ochippendale 👋 Thank you for your post and welcome to the Virgin Media Community 😀
We're sorry to hear about the issue you're facing 😔
In the first instance, please follow the below steps in the following order:
• Turn the power switch off on the back of the Hub
• Ensure the Hub is upright, in a well-ventilated location, and, if at all possible, out of direct sunlight
• Use the power switch to turn the unit back on
If after following the steps the router doesn't boot back up after a few minutes, or the red light returns when it does, it'll need replacing.
Regards,
Daniel- ochippendaleJoining in
Thanks for the assistance.
Unfortunately that has not solved the issue.
Please can you advise as to how to I can get a replacement sent.
- John_GS
Hi ochippendale
Related Content
- 2 years ago
- 3 years ago
- 4 months ago
