Re: Ethernet issue: Powerline adapters not connected
Tezbedz
I have had the same problem since Saturday, although with a Hub 5.0. I have had the hub connected through 2 TP Link Powerline adaptors for about 4 years with no problems.
I have 3 lights on each Powerline adaptor and PC shows a connection but no Internet. if I connect WIFI to my phone I get a signal.
I bought a long cable but that does not work.
My hub is restarting which turns telly on, twice last night once this afternoon. Going to contact Virgin tomorrow
7 REPLIES 7
Use hub in modem mode and get your own router with 1Gb ports
Try a 60 second pinhole reset, do not reboot the Hub as it will reboot itself when needed. Remove any cables before the reset.
Roger_Gooner
Have you done a reset of the adapters?
Note: My username is Roger_Gooner and not Alessandro Volta
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
Daniel_Et
Hi @Tezbedz, thank you for your post.
We're sorry to hear about the problem you've been having 😔
How have things been since you posted? Also, have you considered/tried following the advice provided by @legacy1, @Adduxi and @Roger_Gooner?
Regards,
Daniel
Thanks very much for your help after checking hub, powerline adaptors, cable. I fitted a new ethernet adaptor to PC. Bingo! That was the problem. 900Mbs to Shed.  Flight Simulator is up and running again
I wanted to check everything my end before complaining about hub
For your information, it has also been reported here that any NIC with the Ethernet Energy Saving feature can cause the Hub 5 ports to disconnect.  The solution is to disable the energy saving on the NIC.
Thanks for the update Tezbedz and glad to hear this has been resolved.
If you need us in the future please don't hesitate to get in touch.
Rob
