Hi Tezbedz, thank you for your post.
We're sorry to hear about the problem you've been having 😔
How have things been since you posted? Also, have you considered/tried following the advice provided by legacy1, Adduxi and Roger_Gooner?
Regards,
Daniel
Thanks very much for your help after checking hub, powerline adaptors, cable. I fitted a new ethernet adaptor to PC. Bingo! That was the problem. 900Mbs to Shed. Flight Simulator is up and running again
I wanted to check everything my end before complaining about hub
- Adduxi2 years agoVery Insightful Person
For your information, it has also been reported here that any NIC with the Ethernet Energy Saving feature can cause the Hub 5 ports to disconnect. The solution is to disable the energy saving on the NIC.
- Robert_P12 months agoForum Team
Thanks for the update Tezbedz and glad to hear this has been resolved.
If you need us in the future please don't hesitate to get in touch.
Rob
Related Content
- 5 months ago
- 5 months ago
- 6 months ago
