VincentDalvani's avatar
VincentDalvani
Ongoing Broadband Issue and Request for Technical Support Assistance
I am writing to request further assistance with an intermittent broadband issue that I have been experiencing for nearly a year, which is gradually worsening.
The issue involves my modem entering what I refer to as "zombie mode," where the light remains solid white, indicating that everything appears to be functioning, but there is no internet connection. Upon reviewing the network log each time this occurs, I consistently see the following error message:
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; CM-MAC=XX:XX:XX:XX:XX; CMTS-MAC=**:**:**:**:**:**; CM-QOS=1.1; CM-VER=3.1;
I have contacted support multiple times; however, the telephone support experience has been quite challenging. Due to what seems to be a low-bandwidth VoIP connection, communication is difficult, and operators often struggle to hear me. Most calls have resulted in the suggestion to reboot the modem or perform a factory reset, neither of which have provided a permanent solution.
After escalating the issue, I was finally able to have a technician visit my property yesterday. Although the cable leading into the house was not identified as the source of the problem, the technician replaced it regardless. Unfortunately, he was unable to provide any insight into the modem error logs or suggest further steps to resolve the issue.
Despite this, the problem continues. This morning, I experienced the same "Timing Synchronization Failure" again, which caused a disruption to my work, including disconnections from important Zoom calls. At this point, I am rebooting the modem three or more times a day, which is clearly not a sustainable solution.
It is evident that the issue is not related to the modem or internal cabling, as both have now been replaced. I suspect the problem lies further down the network, but since the fault is intermittent, it has proven difficult to address.
I am seeking assistance from a technical specialist who can analyse the error logs from the modem and provide a long-term resolution. After researching this issue on your forums, I have come across similar reports, many of which seem to end without resolution, which is concerning.
Could you please advise on how I can escalate this matter and get in touch with someone who can interpret the modem logs and address the underlying problem? I believe there are experts within Virgin Media who can resolve this, and I would greatly appreciate your help in facilitating contact with the appropriate team.
  • 26-09-2024 09:48:04 notice REGISTRATION COMPLETE - Waiting for Operational status
    26-09-2024 09:48:00 notice US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    26-09-2024 09:47:55 notice DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    26-09-2024 09:47:54 notice TLV-11 - unrecognized OID;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    26-09-2024 09:47:47 warning DHCP WARNING - Non-critical field invalid in response ;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    26-09-2024 09:47:45 notice Honoring MDD; IP provisioning mode = IPv4
    26-09-2024 09:47:14 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    26-09-2024 09:47:14 critical Cable Modem Reboot because of - Reboot Timezone Change
    26-09-2024 09:44:00 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    26-09-2024 09:43:59 critical Cable Modem Reboot because of - pin-reset
    • Steven_L's avatar
      Steven_L
      Hello VincentDalvani,
      Welcome to the community and thanks for taking the time to post here on the forums. I’m sorry to hear of the issues that you’re having with your connection at the moment.
      I have looked into your connection and in the local area, our system is not showing anything that would be causing the issues that you're having. How has your connection been running since you last posted?
      Kind Regards,
      Steven_L
      • VincentDalvani's avatar
        VincentDalvani
        As shown below, I experienced a complete lack of service last Friday morning between 9 AM and 10 AM. This has been a recurring problem, and I haven’t been able to get any support to figure out what’s going on.
        04-10-2024 09:58:12	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:57:08	critical	SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:57:07	critical	Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:56:49	critical	Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:56:49	critical	SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:56:48	critical	Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:56:48	critical	SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:55:32	critical	SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:55:31	warning	MDD message timeout;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:55:28	critical	SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:44:32	notice	CM-STATUS message sent. Event Type Code: 5; Chan ID: 2 3 4 5 6 7 8 9 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;C
        04-10-2024 09:44:32	notice	CM-STATUS message sent. Event Type Code: 22; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:44:32	notice	CM-STATUS message sent. Event Type Code: 4; Chan ID: 2 3 4 5 6 7 8 9 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.
        04-10-2024 09:44:32	notice	CM-STATUS message sent. Event Type Code: 24; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:44:32	notice	CM-STATUS message sent. Event Type Code: 23; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:44:21	warning	TCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:43:26	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:42:34	critical	SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:42:34	warning	MDD message timeout;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:42:29	critical	SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:42:28	warning	MDD message timeout;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 09:42:25	critical	SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
        04-10-2024 08:51:52	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;
  • @Alessandro Volta
    I wanted to share some insights from the broadband quality monitor I added. It helps show how often I'm facing connectivity issues. I get that outages usually show up as blocks of red, but it seems my router gets stuck in a reboot loop after an outage and can’t reconnect properly. This can leave it unresponsive for quite a while.
    When I'm working from home, having a router that reboots every seven minutes for an hour makes it really hard to get things done. I don’t want to keep saying sorry for leaving and re-joining Zoom meetings due to poor internet.
  • I wanted to share my broadband quality monitor data from October 1st to 7th. It shows a consistent issue every morning throughout the week.
  • 09-10-2024 12:15:07	notice	REGISTRATION COMPLETE - Waiting for Operational status
    09-10-2024 12:15:04	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
    09-10-2024 12:14:58	notice	DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
    09-10-2024 12:14:57	notice	TLV-11 - unrecognized OID;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
    09-10-2024 12:14:51	warning	DHCP WARNING - Non-critical field invalid in response ;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
    09-10-2024 12:14:49	notice	Honoring MDD; IP provisioning mode = IPv4
    09-10-2024 12:14:35	critical	SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
    09-10-2024 12:14:34	critical	Cable Modem Reboot because of - unknown
    04-10-2024 08:51:52	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
    04-10-2024 08:51:01	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
    04-10-2024 08:50:01	critical	No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
    04-10-2024 08:49:06	critical	SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
    04-10-2024 08:49:02	critical	SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
