VWHEROICS wrote:
Hub is fine where it is it's just one room in house that gets no signal..A new hub 5 will sort it. I cannot have the hub by the stairs because ethernet cables aren't long enough to connect to TV in other room..I have had hub in this room before and it's worked fine. Getting new updates hub. Thanks anyway but of course I'll listen to virgin technical
Please do be aware that you haven’t spoken at all to ‘VM technical’, you have spoken to a call centre worker, who probably is a perfectly intelligent individual, but due, to the lack of training has about as much technical knowledge of how this works, as a house brick and are incentivised to tell you anything to get you off the call! Sorry, don’t mean to be offensive, but this is really true!
This person who told you that if the speed was under 10 Mb/s, then you are entitled to a Hub 5, would that be the aforementioned ‘customer service’ provision? If so, then  I”m afraid, you were lied to, no Hub 5 for you! They simply told you what you wanted to hear, closed the call and chalked up another ‘success’. I promise you, absolutely promise you, that no Hub 5 has been ordered and is on its way!
