tonyw2's avatar
tonyw2
No modem mode after overnight VM maintenance outage.
Odd one this.
Last night my broadband went off. VM reported planned network improvements and said it would be finished by 6 AM. When I got up this morning, no broadband. My hub 5 was showing solid white for router mode (but I use modem mode) and my eero mesh WiFi system was not working so no WiFi. I power reset the hub 5 and it came back, still in router mode, but this time the eero system was back up.
Next step was to connect to the hub and change to modem mode, I tried it a few times but the command wouldn't work, so I phoned VM tech support who offered to put the hub into modem mode for me. The hub immediately rebooted into modem mode and everything is now back to normal.
I rely on my broadband to access my security system and one thing that still worries me is, had I been away and unable to initially power reset the hub, would VM have been able to do it remotely or would I have had to return from holiday to do it manually?
  • legacy1's avatar
    Make a note of your firmware version as you likely rolled back on a reset
    I hope VM get the message that their firmware is braking peoples internet when in modem mode
    I would think they have Statistics on this
  • tonyw2's avatar
    tonyw2
    Firmware is "LG-RDK_6.9.35-2302.6", which I'm pretty sure is unchanged.
  • legacy1's avatar
    yes there is a LG-RDK_7.6.10-2306.5 so that might be the reason
    Yes, mu Hub 5 in modem mode was upgraded to the latest firmware recently, but it stayed in modem mode.  no idea why it should reboot into Router mode?  I've always used modem mode for all the Hubs, and never had any problems.  Maybe the Eero was requesting something during the reboot and caused the Hub to go in Router mode?
    Who knows .....
  • tonyw2's avatar
    tonyw2
    Before heading off to bed I've rebooted the hub from the PC web interface and it came back (correctly) in modem mode with the same firmware (LG-RDK_6.9.35-2302.6).
    User network logs are very limited. Can the mods check the records to ascertain exactly what happened last night please?
  • Tudor's avatar
    Possible explanation, guess, the hub was updating to the latest firmware, but suffered a ‘glitch’ during the update process while probably in router, so it could not set itself back to modem mode.
    • tonyw2's avatar
      tonyw2
      If that's the case and it needs a power off/on reset to recover, I'll have to fit a mechanical 24 hour timer and set it to turn off the hub and eero router once a day (for 15 minutes), in the early hours when I'm away, so the worst case should be a 24 hour outage before it all power resets, as I did last year when I was new to VM and unsure of it's reliability.
      • Ashleigh_C's avatar
        Ashleigh_C
        Hi there tonyw2
        Thank you so much for your post and welcome back to the forums.
        I am so sorry that you have faced this issue with your service, can I ask if since the reboot the Hub is behaving as expected now?
  • tonyw2's avatar
    tonyw2
    That's interesting, it looks like legacy1 was right. My hub rebooted in the early hours yesterday and is now on "LG-RDK_7.6.15-2306.5".
    So it probably was a failed firmware update that reset my hub 5 to router mode and required a power reset on my part and VM tech support intervention to get it back into modem mode.
