on 18-05-2022 11:28
I don’t have internet for more than 2 hours. On my hub 3.0 the wifi logo is constant green and the ‘line at the bottom’ is flashing green.
The wifi network seems to be up and running and when I connect to 192.168.0.1
the status is showing that the wifi works but regarding internet is says ‘No RF signal detected’
I can confirm that everything is connected as it should on the box and the fiber cable is indeed connected. The box is also powered well. See the video and photo of the diagnostics.
Could someone help me with that please?
on 18-05-2022 12:29
You have lost the connection to the VM network:
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page http://www.virginmedia.com/servicechecker although this only covers large outages.
VM will not dispatch any technicians when an area fault exists.
If no faults found:
Call Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post.
on 20-05-2022 14:56
Good Afternoon @JeremyBernard, thanks for your post on our Community Forums, and a very warm welcome to you!
Sorry to hear of the issues with the services, I've been able to look into the local area, and the stats of your hub.
There appears to be no issues showing on our side. How has the service performed since your post?
Have you possibly created a BQM?
Kindest regards,
David_Bn
on 23-09-2022 01:24
Hi, I have the same problem. Anyone found a solution?
on 25-09-2022 14:44
Hi Pmedir, welcome to the community! Thank you for posting.
Sorry to hear you are experiencing issues. Sadly we were unable to check our systems to confirm if there are any issues showing on our side.
Ahead of us sending you a PM to confirm some account information and offer further support if you can please give us a little more detail about your case:
Have you tried rebooting or resetting your hub?
Are you experiencing issues with Wi-Fi or a total loss of Wi-Fi ?
Are you experiencing any other connection issues?
Have you checked for any local issues here: https://virg.in/servicechecker or by calling 0800 561 0061?
You should be able to see any issues with your equipment here: https://virg.in/myvmapp
If you can please also post a picture of your hub so we can see the light issue, or a screenshot as Jeremy did at the start of this thread so we can see a little more of what you see!
Thank you! All the best.
on 25-09-2022 17:59
I've rebooted the router a couple of times and nothing. I get a wifi connection but there is no internet connection. The light on the router keeps flashing green.
on 27-09-2022 18:30
Thank you for your reply pmedir.
Can you please confirm which Hub you have with us? Also, can you please let us know which light is flashing and what colour it is?
Are you having trouble connecting multiple devices?
on 19-01-2023 20:58
I'm having the same issue also. Hub 3 installed it on Tuesday and the bottom light is still flashing green. Replugged everything, restarted and even reset it. It connects to WiFi but with no internet
on 19-01-2023 23:02
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
VM will not dispatch any technicians while an area fault exists.
If no area faults found:
The primary place to report faults or for service requests is Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post.
on 22-01-2023 09:01
Hi Nathbeard,
Thanks for your post and welcome to the community.
Apologies for the issues faced, just from checking I can't see any area fault raised.
I've dropped you a PM so we can investigate this further.
The message will appear within the purple envelope icon.
Regards,
