Ktunnah
3 years agoJoining in
New Hub 5 Ethernet ports running slow
Recently moved home and got the new Hub5 with 1000mbps. WiFi is ok, not as good as previous Hub but I see on my dashboard that the ethernet ports at maxing at 100mbps. I can see the Hub itself is getting over 1GB. We use PS4, TV and Sky Stream and all are the same and it’s resulting in a lot of buffering. I’ve tried new cat8 Ethernet cables, done a hard reset on the hub and still getting the same thing. Any ideas? Is it a faulty Ethernet port?
Sounds like a faulty HUB then.
