Outkastarmada76's avatar
Outkastarmada76
9 months ago
New Hub 3 won't connect to garden room
Hi all,
I switched home broadband from Vodafone to Virgin at the weekend.
The router's working fine in the house.
HOWEVER - I have an armoured cable running from my house to a TP-Link access point in a garden room. Under Vodafone, it was working fine, and I had full connectivity. But under Virgin I get a 'connected, but no internet' message.
Does anyone have any idea what I need to do to get it connected...?
Thanks!
  • legacy1's avatar
    VM hub is the problem VM don't understand
    Put hub in modem mode get your own router with 1Gb ports then it will work
  • I presume the cable is an ethernet cable.
    Does the access point show in the list of connected devices when you log into the HUB3 interface at 192.168.0.1 ?
    Be aware that VM uses a different address range to some other ISPs so if the AP has a fixed IP address in the wrong range it will need changing.
    • Outkastarmada76's avatar
      Outkastarmada76
      Yes, the cable is an ethernet cable.
      The AP doesn't show up in the list of connected devices when I log into 192.168.0.1.
      And for what it's worth. even when I plug the ethernet cable directly into the smart TV in the garden room (completely bypassing the AP), there's no connection.
      I've run TP's set-up program many times, but I'm not convinced it's doing anything.
      You mention the address range... how would I change that?
      Thanks!
    A VM Hub in Router mode uses the IP range 192.168.0.xxx
    192.168.0.1 is the Hub menu & Gateway IP
    For Vodafone was the TP-Link Access Point configured for some other IP range perhaps 192.168.1.xxx
    or for a Vodafone Gateway or DNS IPs that are now not available.
  • fizz's avatar
    fizz
    Fibre optic
    Your tp.link access point is notmon the ethernet network. I suspect you need to reset it and run the set up again on it.
  • Sephiroth's avatar
    Sephiroth
    Without being able to give you the precise settings menu details, this is what you have to do:
    1/
    Connect the TP-Link AP to a stand-alone device via WiFi.
    2/
    Go into the TP-Link settings menu and check that it's set into AP Mode.
    3/
    Turn off DHCP which will make it a slave of the VM Hub when turned on.
    4/
    Connect the TP-Link to your Hub.
    5/
    Reboot the TP-Link if it doesn't work immediately.
    If I've missed out a step, someone will put me right.
    Keep us posted.
    "And for what it's worth. even when I plug the Ethernet cable directly into the smart TV in the garden room (completely bypassing the AP), there's no connection."
    That is a very handy test and it should work - assuming the TV is configured to use its network port.
        Help for the next fellow comes from sharing the solution ... regardless of how basic it may be.
