Paul8282
2 years agoOn our wavelength
Network Broadband Congestion (external to home)
How can I identify if VM broadband network congestion is impacting on me? My use of broadband is consistent during any 24 hour period. However, I notice around 6-9pm suddenly everything slows, buffering and slow internet speeds - even though my own use has not altered. Neighbours, also on VM broadband, have noticed the same at similar times.
To avoid confusion on what I am asking, how can I identify if it is VM congestion within their network that is causing this problem? I do not believe it is anything within my home that is causing the issue as use is consistent. I assume VM must have data on this as I am assuming it must be monitored or reported when congestion occurs?
No, they are quite normal. See mine.
