on 13-05-2024 18:48
As a new user, virgin have sent me what looks like a used virgin router 3. The previous owner had a version 4. The wireless signal from the router sometimes does not show, sometimes does not allow connection and sometimes connects with no internet access. This has been happening randomly since initial set up about 2 weeks ago. Here's a an example of the error message in the router log: "No Ranging Response received - T3 time-out;"
on 13-05-2024 19:28
See this...
________
Can we check… are your issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check on one to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
Then.... post up all the Hub data as per this...
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 16-05-2024 14:25
Hi usascottie21,
Thanks for posting, and sorry to see you're having some connection issues.
I've had a look at things from our side, and can see you're affected by an area SNR issue. You might find that your Virgin Fibre, Voice and Virgin TV services are intermittent, with the picture freezing or disappearing now and then.
The estimated fix time is 17 MAY 2024 13:15, if you experience issues past this date please let us know.
Alex_Rm
