Issues with Ethernet Connections and Switches (unmanged)
Up until yesterday morning, I had BT Broadband with the router connected to a 16 port network switch which then ran to other locations and switches (all 1gbps capable) round the house. No problems at all with this setup, connection was always rock solid but I could only get 17mbps from BT.
Upgraded to Virgin yesterday for a 1000mbps internet connection and, since then, the wired LAN has been an absolute nightmare. All WiFi devices (phones, echo dots, Nest doorbell and camera) are working perfectly but wired devices simply aren't connecting to the internet.
As of right now, I have a single device switched on, an Xbox Series X. If I connect it directly to the router via an ethernet cable there are no problems at all but, as soon as I connect the router to a network switch then connect the Xbox to that, the Xbox either cannot connect to the internet and also complains about UPNP not being enabled (it is enabled on the router).
The same is true with my PC which, again, was rock solid when the BT Router was in use, connected via the switch to the router I continually get 'No Internet Connection' when checking the status of the network although the PC can see other devices on the network if they are connected. If I connect the PC directly to the router, it also works perfectly again, the problem only exists if I go through a switch first.
I've tried two different switches (both of which were absolutely fine connected to the BT router) with the same result. Obviously, everything has been rebooted multiple times and this is now driving me up the wall...
Any ides would be appreciated.
I would suggest the following:
- Disconnect all wired devices from the switch.
- Connection one wired device, and manually assign an IP address, 192.168.0.5 for example, and the subnet of 255.255.255.0 (Follow manual as below).
If you can access the switch on 192.168.0.1 you know the reason for the issue!
Here's a link to the full manual to guide you through changing the IP address, as Roger mentioned above (Page 19/20 of the pdf, or 11/12 in the document itself), or even set it to DHCP so it will acquire an IP address from the HUB 5 itself.
