Is this an installation problem?
The_Red_Silence
 Hello
I'm sorry to ask again but is this normal? This cable runs from the new brown box at the side of the house under the garden then to the Virgin media access point on the pavement.
My question is isn't it supposed to have a protective green conduit around it or is this cable "protected" in some other way from the elements.
Thank you
1 ACCEPTED SOLUTION
Accepted Solutions
Looks to me that’s a fibre cable cover, not coax, fibre is inside, so it does not need a green extra cover. That’s why it’s got a green stripe on it to inform other contractors it’s a broadband cable.
4 REPLIES 4
IPFreely
Fibre optic
Indeed: you're looking at the protective conduit there. That's a microduct that'll have the actual fibre cable inside.
https://www.hexatronic.com/en/products/microducts-and-microduct-assemblies/direct-buried-thick-walle...
Just FYI the stripe is there to help identify different ducts in a bundle. The green stripe itself doesn't mean anything.
The_Red_Silence
Thanks for all the help 👌
