skylineboy2002's avatar
Internet still not quite right after Cable Repull
hi guys.
a loooong battle, but yesterday (after being told itd be the 16th) a chat agent thought outside the box and i got a cable repull done (the lads who came said they got an urgent call 10 mins before they showed up lol).
cable all fine, a neat job by their sub contractors from what i can see and know.
however my BQM looks "messy"? and i even had dropouts on basic things like iplayer whilst i was chatting with agent about bill credits for the issue etc.
i do note that my brown outside box, is around 2-3m away from my actual tv point inside - (theres cables from near front door under window (outside cabling) and then into the tv corner) - could this be the issue? is that kinda like an extension? from brown outside box to inside white one
i've got a test.mynet test running - every 5 mins for the next 8hrs so ill see what averages and stuff that gives over that timeframe but already onto test 3 and 1 has been merely 1mbps.
engineer is booked for monday am, any suggestions before then or to help guide them? i was reading about attenuators becasuse i noticed some downstreams powers are 9.3-11.0 which from my reading on here ./ guides seems high?
i should add that i've been in this property over 3 yrs, and it's worked perfectly since august, where it just went down hill. With no changes to property or equipment etc to trace back to (i was given a new hub my first engineer, but i use modem mode anyway, and the new hub didnt change anything, it was still rubbish).
https://www.thinkbroadband.com/broadband/monitoring/quality/share/f8e987c8e021aa4c882b34216aebc62936f81981
  • i should add that i've been in this property over 3 yrs, and it's worked perfectly since august, where it just went down hill. With no changes to property or equipment etc to trace back to (i was given a new hub my first engineer, but i use modem mode anyway, and the new hub didnt change anything).
  • jbrennand's avatar
    Thats one weird BQM !   Can you do this
    ________________________________
    Post up your Hub/network connection details and someone will check to see if there is a problem there.  In your browser’s URL type in 192.168.0.1 if in router mode or 192.168.100.1 if in modem mode. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
    Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
    __________
    Also post the BQM link to "share live graph" as per the TB  instructions
  • heres the live bqm link -
     and the data.
    132300000010.538256 qam24
    220300000010.438256 qam9
    321100000010.438256 qam10
    421900000010.438256 qam11
    52270000001038256 qam12
    623500000010.338256 qam13
    72430000009.838256 qam14
    82510000001038256 qam15
    92590000001038256 qam16
    102670000001038256 qam17
    112750000001038256 qam18
    1228300000010.438256 qam19
    1329100000010.538256 qam20
    1429900000010.638256 qam21
    153070000001138256 qam22
    1631500000010.438256 qam23
    1733100000010.938256 qam25
    1833900000010.838256 qam26
    1934700000010.338256 qam27
    2035500000010.538256 qam28
    2136300000010.138256 qam29
    2237100000010.138256 qam30
    233790000001038256 qam31
    243870000009.638256 qam32
    1Locked38.9150
    2Locked38.9150
    3Locked38.6190
    4Locked38.9120
    5Locked38.6270
    6Locked38.6280
    7Locked38.6210
    8Locked38.9320
    9Locked38.6350
    10Locked38.9340
    11Locked38.9330
    12Locked38.9180
    13Locked38.9120
    14Locked38.9100
    15Locked38.9190
    16Locked38.9180
    17Locked38.9120
    18Locked38.980
    19Locked38.9100
    20Locked38.9220
    21Locked38.9120
    22Locked38.9100
    23Locked38.9260
    24Locked38.631
    0
    14310007837.3512064 qam2
    23660000037512064 qam3
    33010000037.5512064 qam4
    44960000038.5512064 qam1
    52360000936.5512064 qam5
    3ATDMA0000
    4ATDMA0010
    5ATDMA0010
  • and the network log -
    03/10/2024 19:24:6criticalNo Ranging Response received - T3 time-out;CM-CMTS-MAC;CM-QOS=1.1;CM-VER=3.0;
    03/10/2024 14:45:32criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
    03/10/2024 14:43:15Warning!Lost MDD Timeout;CM-MAC=CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
    03/10/2024 14:43:10Warning!RCS Partial Service;CM-MAC=CMTS-MAC=QOS=1.1;CM-VER=3.0;
    03/10/2024 14:43:10criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MACCMTS-MACCM-QOS=1.1;CM-VER=3.0;
    03/10/2024 14:43:10Warning!RCS Partial Service;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
    03/10/2024 14:43:10criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MACCMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
    03/10/2024 09:04:15Warning!RCS Partial Service;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
    03/10/2024 09:03:3criticalNo Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
    03/10/2024 09:02:35Warning!RCS Partial Service;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
    02/10/2024 11:31:58criticalNo Ranging Response received - T3 time-out;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
    01/10/2024 05:49:27ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=CMTS-MAC=00CM-QOS=1.1;CM-VER=3.0;
    • skylineboy2002's avatar
      skylineboy2002
      Oh dear. That doesn't fill me with hope lol.
      Good luck with yours.
      • Ashleigh_C's avatar
        Ashleigh_C
        Hi there skylineboy2002
        Thank you so much for your post and welcome back to the community forums.
        I can see that you are already in a PM with our team, please do pop back to them and they will look into this further with you.
