3 weeks ago
Hiya,
That last 10 days I've had internet issues and dropouts. Streaming TV/Film pauses, games disconnect, discord lags and drops, websites delay.
I am ethernet checking.
Modem mode.
Wired household.
Checking the router section I can see these types of issues:
25-05-2024 22:19:31 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
25-05-2024 22:01:01 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
25-05-2024 21:49:43 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
24-05-2024 20:17:25 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Currently the modem has a 10db filter on it.
Is this something you can do your end?
Can you advise or arrange an engineer to resolve, thank you
3 weeks ago
Post up the whole data set as per this...
___________________________________
Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
3 weeks ago
Hi John, thanks and np here you go.
27-05-2024 13:37:48 | notice | CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 13:37:18 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 13:33:11 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 13:29:03 | notice | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 13:28:37 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 13:28:37 | warning | Dynamic Range Window violation |
27-05-2024 13:28:35 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 13:26:16 | notice | CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 13:25:43 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 13:25:42 | warning | Dynamic Range Window violation |
27-05-2024 13:25:42 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 13:25:42 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 13:25:41 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 13:11:10 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 12:24:46 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 12:24:46 | warning | Dynamic Range Window violation |
27-05-2024 12:24:46 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 12:24:44 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 12:23:59 | notice | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 12:22:22 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 12:22:07 | notice | CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 12:17:19 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 11:27:13 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
3 weeks ago
27-05-2024 20:51:12 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 20:51:11 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 20:51:09 | warning | Dynamic Range Window violation |
27-05-2024 20:51:09 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
3 weeks ago
Ive been getting small disconnects which stops streaming services and times me out in games this evening,
3 weeks ago
https://www.thinkbroadband.com/broadband/monitoring/quality/share/25bbcc343117907084c42cc71f56e3f806992fc1-27-05-2024
3 weeks ago
I'm seeing a bit of packet loss on the BQM (although not this evening)
Could you please also post the upstream and downstream logs?
3 weeks ago
3.0 Downstream channels
1 | 331000000 | 5.2 | 43 | QAM 256 | 25 |
2 | 139000000 | 3.9 | 42 | QAM 256 | 1 |
3 | 147000000 | 3.8 | 42 | QAM 256 | 2 |
4 | 155000000 | 3.6 | 42 | QAM 256 | 3 |
5 | 163000000 | 3.8 | 42 | QAM 256 | 4 |
6 | 171000000 | 4 | 43 | QAM 256 | 5 |
7 | 179000000 | 4 | 43 | QAM 256 | 6 |
8 | 187000000 | 4.1 | 43 | QAM 256 | 7 |
9 | 195000000 | 4.2 | 43 | QAM 256 | 8 |
10 | 203000000 | 4.3 | 43 | QAM 256 | 9 |
11 | 211000000 | 4.5 | 43 | QAM 256 | 10 |
12 | 219000000 | 4.5 | 43 | QAM 256 | 11 |
13 | 227000000 | 4.6 | 43 | QAM 256 | 12 |
14 | 235000000 | 4.3 | 43 | QAM 256 | 13 |
15 | 243000000 | 4.1 | 42 | QAM 256 | 14 |
16 | 251000000 | 4.2 | 43 | QAM 256 | 15 |
17 | 259000000 | 4.4 | 43 | QAM 256 | 16 |
18 | 267000000 | 4.6 | 43 | QAM 256 | 17 |
19 | 275000000 | 4.8 | 43 | QAM 256 | 18 |
20 | 283000000 | 4.7 | 43 | QAM 256 | 19 |
21 | 291000000 | 4.9 | 43 | QAM 256 | 20 |
22 | 299000000 | 5.2 | 43 | QAM 256 | 21 |
23 | 307000000 | 5.5 | 43 | QAM 256 | 22 |
24 | 315000000 | 5.5 | 43 | QAM 256 | 23 |
25 | 323000000 | 5.4 | 43 | QAM 256 | 24 |
26 | 339000000 | 5.5 | 42 | QAM 256 | 26 |
27 | 347000000 | 5.5 | 43 | QAM 256 | 27 |
28 | 355000000 | 5.4 | 43 | QAM 256 | 28 |
29 | 363000000 | 5.2 | 43 | QAM 256 | 29 |
30 | 371000000 | 5.1 | 43 | QAM 256 | 30 |
31 | 379000000 | 5.3 | 43 | QAM 256 | 31 |
1 | Locked | 43 | 124259 | 28935 |
2 | Locked | 42 | 148038 | 16563 |
3 | Locked | 42 | 317512 | 65812 |
4 | Locked | 42 | 474805 | 47383 |
5 | Locked | 42 | 451228 | 58967 |
6 | Locked | 43 | 437944 | 89849 |
7 | Locked | 43 | 354657 | 106902 |
8 | Locked | 43 | 258682 | 56634 |
9 | Locked | 43 | 185613 | 15494 |
10 | Locked | 43 | 49433 | 8308 |
11 | Locked | 43 | 169213 | 13882 |
12 | Locked | 43 | 155306 | 13327 |
13 | Locked | 43 | 136823 | 10412 |
14 | Locked | 43 | 139896 | 12232 |
15 | Locked | 42 | 199832 | 17896 |
16 | Locked | 43 | 133009 | 10137 |
17 | Locked | 43 | 121256 | 17893 |
18 | Locked | 43 | 140518 | 15990 |
19 | Locked | 43 | 132841 | 14998 |
20 | Locked | 43 | 89732 | 11768 |
21 | Locked | 43 | 92815 | 13699 |
22 | Locked | 43 | 113044 | 12900 |
23 | Locked | 43 | 100817 | 12629 |
24 | Locked | 43 | 96890 | 11516 |
25 | Locked | 43 | 95918 | 11590 |
26 | Locked | 42 | 69099 | 13521 |
27 | Locked | 43 | 94638 | 18972 |
28 | Locked | 43 | 86601 | 15035 |
29 | Locked | 43 | 86067 | 16195 |
30 | Locked | 43 | 81888 | 15075 |
31 | Locked | 43 | 84841 | 20442 |
3.1 Downstream channels
33 | 94 | 4K | 1840 | QAM 4096 | 1108 |
33 | Locked | 43 | 4.6 | 1280172612 | 232623 |
3 weeks ago
3.0 Upstream channels
0 | 49600000 | 40.3 | 5120 | QAM 64 | 1 |
1 | 43100000 | 40 | 5120 | QAM 64 | 2 |
2 | 36600000 | 40 | 5120 | QAM 64 | 3 |
3 | 30100000 | 39.8 | 5120 | QAM 64 | 4 |
4 | 23600000 | 39.8 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 41 | 0 |
1 | ATDMA | 0 | 0 | 48 | 0 |
2 | ATDMA | 0 | 0 | 84 | 0 |
3 | ATDMA | 0 | 0 | 115 | 0 |
4 | ATDMA | 0 | 0 | 201 | 0 |
3.1 Upstream channels
6 | 10.4 | 35.2 | 2K | QAM 256 |
6 | OFDMA | 208 | 74000000 | 15 | 0 |
3 weeks ago
Stats dont look good - but may be historical accumulation - so can you try this....
__________________
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing. Also check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables. Then switch the Hub back on and leave ~5 minutes When all done, check back in the settings and ensure that the Post RS error counts and T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. If they do (particularly the PostRS and T3 ones) you have a problem (noise) that only a Tech visit will sort.
Also check the Upstream QAM’s are all at 64
