bigmark444's avatar
bigmark444
11 months ago
Intermittent Broadband and TV problem
Been having problems over the past few weeks with both my broadband and TV. They are both dropping out for 1 hour plus at the same time. So far it’s happened on:
Thur 22nd August @ 2pm
Fri 23rd August @ 9am then again @ 12pm
Fri 30th August @ 9pm
When it happens, the hub (Hub 5) will have a red light. Rebooting it usually results in a flashing yellow light, for maybe 1-2 hours, before finally returning to green… At the same time the TV will either show a message about “There is a problem with the signal. Please reboot your TiVo box”, or will be so pixelated that it’s unwatchable (video available showing viewing experience). Rebooting doesn’t resolve the issue. Again it usually returns after 1-2 hours
Lastly when this has happened, a few times I have called the outage phone number, but no outages in my area
  • jbrennand's avatar
    You need to start compiling a record of any breaks in connectivity - start a BQM
    If you haven’t already, set up a free, secure and “offlsite” - “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph”. Click the lower link (Share Live Graph) then, click generate. Copy the text in the Direct Link box, beware, there may be more text than you can see. On here click the Link icon (2 links chain to the left of the camera icon) In the URL box paste the link you copied and then click OK
  • I should also clarify, the light in my hub is currently flashing red. When I reboot the hub, the light will turn to a flashing yellow light, and stay like that for multiple hours
    On the TV box, when this happens some channels are heavily pixelated, while others are displaying the error code W02. It displays the arrows light on the box
    • Kath_P's avatar
      Kath_P
      Hi bigmark444,
      We're sorry to hear you've been having issues with your broadband and TV services. Checking things here, I can see since posting, an engineer visit has taken place.
      How have things been since the visit? Let us know so we can help further.
