Daveg14's avatar
Daveg14
Up to speed
IP Location Wrong
I have noticed my IP address was changed to another one which I know  it happens I only found out when  I was doing a speediest app and the locations were no longer near me  location comes up as MiddlesbroughUnited Kingdom not where i am on the South Coast.
One site you can look up where your IP address is from was wrong and I was able to update that one to where I am
I tried IP renew and release but that  did not resolve
anyone have any one with any ideas let me know many thanks
David
  • VM IP addresses are not static - just sticky.  They can change for no apparent reason - mine has changed twice in the last 3 years.  Not much you can do about it other than adapt to the new one.
    What is the issue doing that?  Note that if you put the Hub into modem mode that will be a different IP address too and you can "toggle" between the two.
  • jbrennand's avatar
  • Tudor's avatar
    Nothing VM can do about it. Search the board for similar posts, they contains lots of explanations. I for one a happy to have my IP pointing to another part of the country.
    "IP Location Wrong" - How it this affecting your internet usage ?
    • Daveg14's avatar
      Daveg14
      Up to speed
      Internet is as normal because because it says VM Cosham which is where it should be connecting as close to me.
  • Thank you to everyone who replied to my question
  • UPDATE
    I used a IP lookup site there it gave option to change to my location on that site then a few days latter I used the speedtest app and it was showing places near me.as it did before IP change
