Kaisybear's avatar
Kaisybear
I keep dropping connection, making gaming near impossible.
I am sorry for bothering but i need help. I keep dropping in and out with my connection, making gaming with friends near impossible. I have reset the hub, moved it, reseated the cables, did the thing with the disable auto channel stuff and i still get dropped. I love the speeds but it has made gaming near impossible.
  • jbrennand's avatar
    Can we check… are your issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check on one to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
    Gaming is always best done on an ethernet cable connected device - so "engineer" that if you can
    What Hub model is it? What are the various Hub lights showing/doing when this happens if a Hub3 is the base light a steady white(ish) or flashing green?
    • Kaisybear's avatar
      Kaisybear
      It appears to be from everyone in the home but most prominent with me. I have a ethernet cable hooked up so it isn't wi-fi. The hub appears to be the hub 5 and the lights are solid white.
      • Ashleigh_C's avatar
        Ashleigh_C
        Hi there Kaisybear
        I am so sorry that you have faced this issue with your service and thank you so much again for your post, I have not been able to locate your account to check this issue so I'm going to pop you a quick private message so I can grab some information and check this on our side.
