dw2021
12 months agoTuning in
Hub4 able to get full Gig1 speed
I am considering upgrading from 260Mbit to Gig1.
I currently have a Hub4 - I see Gig1 mentions 1130Mbit/104Mbit Dl/Ul speeds. Is the Hub4 suitable for these speeds or do I need additional equipment?
I have wifi6 and 2.5Gig Network ports on equipment Id like to use to take advantage of the speed.
The Hub 4 as you know only has 1Gb ports, so approx 940 meg. You can however saturate the full speed over WiFi if using multiple clients. I’m sure lots of users will be advising you to push for the Hub 5.
