Joll's avatar
Joll
Hub3 issues - permanent red light
Having troubles with broadband/wifi hub is showing permanent red light, tried all suggestions for a cure. Getting intermitent cutting off internet access and intermitent noise on audio. Laptop is using hardwired ethernet.
Any ideas ?
Cheers
Peter
  • If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly.
  • Hey Joll, thank you for reaching out and I am so sorry to hear about this.
    Let me send you a DM to get this resolved, in the meanwhile please try these steps;
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
    • Joll's avatar
      Joll
      Thanks Mate tried the reset and can confirm hub is well ventilated and not in sunlight, still red and having drop outs
      • Ayisha_B's avatar
        Ayisha_B
        Hi Joll
        Please do respond to my colleagues PM and an engineer will be booked for you so the hub can be replaced.
