3 years agoVery Insightful Person
Hub 5 reboots
Had this error twice now in less than a month. Seems like a failure to update the Hub to the latest firmware, as it is still on the previous one. The downside is this takes the Hub offline for a couple of hours as noted on my BQM. Hopefully it will be third time lucky and it might work ...........
01-11-2023 02:37:02 notice SW Download INIT - Via Config file
01-11-2023 02:37:02 error SW Upgrade Failed Before Download - Server not Present
01-11-2023 02:36:07 critical Cable Modem Reboot via RG reboot command
Zoie_P Thanks for the checks from your end.
I did a pinhole reset yesterday, and the Hub 5 is now on the correct version LG-RDK_6.9.35-2302.6 and is reporting the full Docsis 3.1 stats.
Cheers š
