proudgace's avatar
proudgace
Hub 5 Needs rebooting daily
Had a Hub 5 for about 3-4 months, and over the past month I’m needing to switch my hub off and on again at least once a day. It just loses connection for some reason, and this seems to sort it.
virgin seemed to notice when it first started, and apparently offered to send an engineer out (which I never got an email asking for), but now I can’t seem to get anyone out.
ive followed all the troubleshooting steps, but nothing seems to improve it.
i used to have a TP link router and this ran with no issues, and if things don’t improve I’m going to have to go back to it I think.
my 2 kids are getting really annoyed with our “crappy new broadband”, but I thought this Hub 5 was supposed to be an improvement?
  • Check for known faults in your street  ( be sure to use both methods )
    Call 0800 561 0061 – this is an automated number.
    https://www.virginmedia.com/help/check/status/identification/identify
    Downstream signals are low / too low
    Downstream Power Levels should be -7 to + 7 dBmV for optimal performance.
    The 3.0 Downstream are approaching -7 and channels # 30 to 32 are just below the -7 dBmV mark,
    there is a smattering of Post RS errors across all channels.
    3.0 Downstream channels
    30371000000-7.139QAM 25630
    31379000000-7.140QAM 25631
    32387000000-7.239QAM 25632
    The 3.1 Downstream channel is considerably worse at -12.3 dBmV,     ( vs -7 to + 7 preferred )
    as this is a logarithmic scale the received power is well below normal & is resulting in Uncorrectable errors.
    3.1 Downstream channels
    159Locked37-12.3678198791183891
    Do the connection stats look like an engineer is needed ?
    Look at Hub menu >>> Check router status >>> Downstream & Upstream tabs
    Copy / paste the text into this thread ( no screen shots please, they are too small to read )
    of the two tabs if you would like a hand in reading the figures.
    • proudgace's avatar
      proudgace
      1331000000-5.740QAM 25625
      2139000000-3.140QAM 2561
      3147000000-3.140QAM 2562
      4155000000-3.440QAM 2563
      5163000000-4.140QAM 2564
      6171000000-4.340QAM 2565
      7179000000-3.840QAM 2566
      8187000000-3.640QAM 2567
      9195000000-3.740QAM 2568
      10203000000-3.940QAM 2569
      11211000000-440QAM 25610
      12219000000-4.540QAM 25611
      13227000000-5.340QAM 25612
      14235000000-5.440QAM 25613
      15243000000-5.440QAM 25614
      16251000000-5.540QAM 25615
      17259000000-5.440QAM 25616
      18267000000-5.240QAM 25617
      19275000000-5.140QAM 25618
      20283000000-5.140QAM 25619
      21291000000-5.240QAM 25620
      22299000000-5.340QAM 25621
      23307000000-5.440QAM 25622
      24315000000-5.440QAM 25623
      25323000000-5.640QAM 25624
      26339000000-5.640QAM 25626
      27347000000-5.840QAM 25627
      28355000000-6.140QAM 25628
      29363000000-6.440QAM 25629
      1Locked40790
      2Locked40789360
      3Locked40653296
      4Locked40410132
      5Locked40295115
      6Locked4030244
      7Locked40322105
      8Locked40456124
      9Locked40732259
      10Locked40603434
      11Locked40487369
      12Locked40616165
      13Locked4041491
      14Locked4016410
      15Locked4054752
      16Locked4031587
      17Locked40430136
      18Locked40476140
      19Locked4034992
      20Locked4028290
      21Locked402482
      22Locked4026145
      23Locked4022940
      24Locked4024984
      25Locked4027112
      26Locked40720
      27Locked401700
      28Locked401840
      29Locked40410
      30Locked391410
      31Locked4029027
      32Locked3929320
      159944K1840QAM 40961108
      3.0 Upstream channels
      04960000052.35120QAM 641
      14310000052.35120QAM 642
      23660000052.85120QAM 643
      33010000051.55120QAM 644
      42360000050.35120QAM 645
      0ATDMA0000
      3ATDMA0040
      4ATDMA0000
      3.1 Upstream channels
      61046.72KQAM 256
      6OFDMA2007400000000
      proudgace
      I’m not massively technical, but you’re suggesting there’s an issue - thanks for checking over that.
      i have an engineer booked for tomorrow - is this something I’d need to show them? Does this point to an issue with the router or something in my area?
    Normally an engineer connects a test meter in place of the VM Hub to check the signal levels.
    But it can not do any harm to mention you have seen the Downstream signal levels
    are showing as low in the Hub's status pages.
  • I got problem with hub 5 after upgrade contract from hub 3.
    Costant rebooting every 5 minutes.
    • Daniel_Et's avatar
      Daniel_Et
      Hi onyx84d, thank you for your post.
      We're sorry to hear about the problem you've been having 😔
      I can see you've spoken to the team since you posted. Has a resolution to the problem been provided?
      Regards,
      Daniel
