Hub 5 Power Lead Length.
kibbs70
How long is the Hub 5 power lead, please? I currently have a Hub 3 (M250) and am looking upgrading to 1Gb speed. Apparently, I will receive a Hub 5 for this. However, I currently use a 3rd party power lead for my Hub 3 as the original was too short. Could anyone advise the length of the Hub 5 power lead, and maybe also a photo of it, please? The photo is just to establish if it is likely to fit where I need it to go.
Thanks in advance for ant help or advice.
Paul.
1 ACCEPTED SOLUTION
Accepted Solutions
Yep! (Excuse the dust, measured from either end as I didn't want to unlpug!):
6 REPLIES 6
More likely you will get a Hub4 - as its an "upgrade".   So check for both.
EDIT: IIRC they both have a power pack which connects on a "kettle" universal power lead - so you can just swap that for a longer one
The HUB 5 doesn't come with a kettle lead, it's a PSU integrated into the plug (Cable length 66 inches):
Thank you for the info. 66 inches seems really long, though - that's 5 and a half feet! 🙂
Perfect! Thank you so much for that.
