Hub 5 - Periodically losing LAN
chronicbint
Over the last year my wired connection has been failing on the Hub 5.
The wired connection will just sit at "unidentified network". No amount of reboots or reconnections will fix it.
The only way I have found to resolve this is a factory reset, It then works instantly.
This has happened around 4 or 5 times in the past year.
WiFi remains unaffacted
10 REPLIES 10
Hello chronicbint.
Thanks for your private message.
It is good to know the service is working okay now after your router purchase.
If you need anything else, please don't hesitate to pop back on here.
Gareth_L
