2 weeks ago - last edited 2 weeks ago
Around 10:30am today my fiber broadband dropped and my Hub 5 router started flashing blue. Initally I rebooted the router and still no luck.
I then checked the routers diagnostic via the routers webpage, and it showed it had no broadband connection.
Checking the service status page on the Virgin Media website showed there was no local area faults. The blue light persisted, after following webpage advice about checking connections and rebooting.
I have then checked the router status on the routers local webpage, with these results.
Info
Standard specification compliant: ITU-T G.9807.1
Hardware version: 1.2.1b
Software version: 2.40.13-2210.4
ONT MAC address: ██:██:██:██:██:██
ONU serial number: ████████████
System up time: 0day(s)0h:12m:6s
Network access: Allowed
WAN IP settings
IPv6 address: /128 ████::████:████:████:████/64
IPv6 default gateway: ::
IPv6 lease time: D:49710 H:6 M:28 S:15
IPv6 lease expire: Fri May 23 16:56:14 2160
IPv6 DNS servers:
IPv4 address: 0.0.0.0
Default gateway: 68.21.112.246
IPv4 lease time: D:0 H:0 M:0 S:0
IPv4 lease expire: Tue Apr 16 10:27:59 2024
IPv4 DNS servers:
Router status
PON modem status Online
Connection mode IPOE
Firewall true
WAN layer interface
IP_VOIP Up
IP_DATA Up
PON statistics
Transceiver temperature 23
Transceiver voltage 3306
Laser bias current 9534
ONT transmit power -16800
ONT receive power 5100
General Configuration
Network access Allowed
Maximum Number of CPEs Not Available
Baseline Privacy enabled
PON Mode GPON
3 Jul 23:06:57 notice system.syscfg commit to store
3 Jul 23:06:48 notice GUI Login Status - Login Success from LAN interface
What appears to be odd here, is that the IPv4 lease has expired Tue Apr 16 10:27:59 2024 - which corresponds to when I lost connection.
So the question is, why hasn't my Hub 5 been issued a new IPv4 address, and how can I resolve this issue?
Answered! Go to Answer
2 weeks ago
This is XGS-PON on a Hub 5x - call Customer Support on 0345 454 1111 ASAP and report the service outage.
Don't wait here for 3 days only to informed VM Mods can't help with XGS-PON / Hub 5x installations.
2 weeks ago
2 weeks ago
Thanks for the advice. I've just checked via the 0800 561 0061 service number, which is now reporting a large area fault. Which isn't showing up on the online service 🙄.
Do I still report the service outage in this instance?
2 weeks ago
The online checker needs most of Colchester to be blacked out before it registers faults for us.
The 0800 561 0061 tends to focus down to street by street level, which is more useful.
Up to you if you wish to call Customer Support for an known fault.
