robatwork
3 years agoOn our wavelength
Hub 5 / 192.168.0.1 / Change IP range
Just bought a new Hub 5 to replace a Hub 3, to help with wifi speeds.
Having had a quick root around here it looks like VM removed the ability to change the IP range, which is going to cause me a problem as I VPN into work which is on 192.168.0.0/24.
Other than using my own router behind the Hub 5 in modem mode (which I don't want to do for various reasons), is there a secret unpublished method to change the hub's IP that I haven't discovered in a quick google? My DM's, as they say on X, are open.
Thanks in advance
