on 08-02-2024 10:59
The Hub 3.0 is rebooting every night at 2am. The connection drops when using the internet at that time and the Hub 3.0 settings show an up time of how ever many hours since 2am. This has been happening every night since the service activation 12 days ago. The previous account holders service was only disconnected the day before and their connection was ok. There are no outages or maintenance showing on the Virgin Media website. I have tried using the supplied coaxial cable and the one left from the previous account holder. I have tried resetting the Hub 3.0. I can't get through to a customer service agent via live chat.
on 08-02-2024 13:33
Ive been getting the same issue with my Hub 5, but only on Tues, Weds and Thurs Morning, all between 2:00-2:50am
Been told its trying to do a software update, and it cant because I have my hub 5 in modem mode. Even after it did an update, it still reboots.
Are you using the hub 3 in router or modem mode ?
on 08-02-2024 13:54
In cases like this it's useful to set up a free BQM, which will show and record the dropouts. If you follow the instructions to post a live link in this thread, it will help to show what's going on.
on 08-02-2024 14:01
Ive got the same issue with my hub 5. I had the reboots last year but after an engineer attended and changed the attenuator it fixed the rebooting. Nothing has changed my side and now Ive had reboots between 2 and 3 the last 3 mornings. Hub 5 is in modem mode.
My thread last year
on 08-02-2024 14:42
@HUGH_EFFO wrote:<snip> Been told its trying to do a software update, and it cant because I have my hub 5 in modem mode. <snip>
No, that's not the case. All my VM Hubs have been in modem mode, and my latest Hub 5 updated last night. Modem mode is not the issue.
on 08-02-2024 16:23
I doubt if modem mode is anything to do with the rebooting. Check the power levels, Pre and PostRS errors and the Network log. The only other thing is the 60 second pinhole reset.
on 09-02-2024 09:32
what does the Hub log say is the reason for the reboot. Mine always say "Cable Modem Reboot because of - unknown"
No reboot this morning, but if the pattern continues the next re-boot will be Tues Morning between 2-3am
VM has to be doing something with the network, or has switches with auto reboot timers, which intern causes the hubs to reboot.
on 09-02-2024 10:56
on 12-02-2024 08:41
Mine always does it Tues, Weds and Thurs Mornings between 2:00 and 2:50am
on 12-02-2024 15:07
Hey Martyn24, thank you for reaching out and a warm welcome to the community I am sorry to hear this.
After checking there was an outage at the time of this which lasted for 3 days but has now ended.
We also would do software updates around this time, how has it been over the weekend?
Matt - Forum Team
New around here?
