- nodrogdVery Insightful Person
A continually flashing green base light means the hub is unable to lock onto any signal coming through the white coaxial cable. Check the coaxial cable is tight in the back of the hub & then check the service status line for area faults (0800 561 0061). 9 times out of 10 this is a fault on the local network, but it may be a cable failure at the property, or a failed hub.
- Daniel_EtForum Team (Retired)
Hi Andyuk2024 👋 Thank you for your post and welcome to the Virgin Media Community 😀
We're sorry to hear about the problem you're having 😔
Have you tried following the advice provided by nodrogd? If so, has the problem now been resolved?
You can also check your service status by clicking here.
Regards,
Daniel
Related Content
- 2 years ago
- 2 years ago
- 1 year ago
- 5 months ago
- 2 years ago
