Mangraviti's avatar
Mangraviti
Help accessing modem mode
I'm sick and tired of this modem and I can't find a straight answer to my question.
I run my Hub 3 in modem mode and I have a proper router to do all my networking and VPN.
The VM Hub is said to be on 192.168.100.1.
My router is on 192.168.100.2. It has a range from 100.1 to 100.254.
How in the name of god can I access the modem?
192.168.100.1 simply won't respond.
And if your answer is to set the Hub to router mode, don't bother answering my question.
Does anyone actually know how to do this?
Thanks in advance
  • No, contrary to popular belief the hub isn’t on 192.168.100.1 when in modem mode, better described as ‘bridge mode’, that’s the internal web server interface address.
     In bridge mode, the VM hub, ‘passes on’ a public address to your own router’s WAN interface, so you need to set that to be DHCP, or dynamically assigned or however they phrase it for your model. What you set for the LAN-side address is irrelevant really.
