Having problems with broadband dropping
Joll
broadband dropping on both wifi and wired connections, also tv screen is flickering.could I have an intermitent cable fault ? Hub 3 recently change for another hub 3. Is ther a problem with hub 3s ?
Finger crossed as I know intermitent faults are difficult to find
Cheers
Peter
PS broadband dropped while posting this message
7 REPLIES 7
Cardiffman282
Problem sorter
Check for local faults on 0800 561 0061 and ensure all cables and connections are tight and in good condition.
Cancel VM here
Complain to VM
here
Demand compensation from VM here
Demand your call recordings here
Monitor the state of your VM connection here
All internal connections are tight and were checked by engineer when visiting to replace faulty hub 3. Perhaps external connections could be at fault
Hey Joll,
Welcome back to the community and thanks for taking the time to post. I’m sorry to hear of the issues that you’re having with your services at the moment. I have looked into this and cannot see anything that would be causing such issues with your connection. Are you still experiencing the issues at the moment?
Kind Regards,
Steven_L
Hi Steven, thanks for the response I've been having trouble for a while but the last 3 weeks or so things seem to be getting a bit more often. The hub was changed a short while back as it had a red light rather than white. At that time the internal wiring was checked and found to be ok.
As the problem seems to affect both tv and broadband my suspicion is some sort of cable/connector issue outside my property
Regards   Joll
Thanks for getting back to us @Joll
Do you have issues with your wired devices or is it just over WiFi that you're having the drops in connection?
Here to help 🙂
Virgin Media Forums Agent
Carley
As previously stated both wired and wifi drop out plus intermitent tv flickering
Hi @Joll
Thanks for confirming.
Can you start and upload a BQM for us please?
Best wishes.
John_GS
